Fuel sending unit
Hi all, any opinios on whether it is easier to drop a saddle tank or move the bed to get at the sending unit on my 75 C20??
Re: Fuel sending unit
I have never removed the bed of mine, but dropping the tank isn't that hard. It can be heavy if it has fuel in it. I'm about to drop mine, I'm in the process of running mine dry so its easier to work with.
Thanks, I'm just curious as to how to get the fuel lines off I can't really get a good purchase on them
![]() Join Date: Oct 2011
I'm interested as well... since I'll be doing this soon.
1987 R10 1976 K10 |
I'd drop the tank. Disconnect the lines after you lower it a few inches.
thanks heavy, doesn't look like there is enough hose for it but i'll give that a try
If you have help you can lift off the bed...
Its way easier to drop the tank. Put a jack and a couple jack stands under it and remove the bolts. You can disconnect the rubber lines from the hard lines under the bed. Just be sure to remove the little strap from the frame that holds the lines.
Moderator
![]() Join Date: Oct 2008
Dropping the tank is a PITA. The sender hoses never cooperate with me. If I'm not replacing the tank I pull the bed. It's much quicker.
I've pulled a bed in 15 minutes or less with help for 2-3 minutes of it. 3-4 guys can move an unhooked long bed to sawhorses real quick. I've done a shorty with just two of us. Unplug the taillights on the LH frame rail and the license lights at the center. Undo the filler neck and pull the rubber couplers. New bed bolts are cheap. If they don't move with a 3/8" ratchet I cut em off.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
if yo have access to a motorcycle jack or tranny jack the job gets easier, if not well make sure the tank is empty, 4 bolts and 3 hoses and goes down, remember to disconect the ground wire.
Only took me 30 min to drop mine,floor jack under it makes it easy! that was the passenger side ,had one on drivers side ,but removed it 8 years ago,ya know the exploding on impact thing!
all you have to do is unhook the line as the switching thing and then just drop the tank. but be for you do plug the lines so nothing get in it. if its empty it takes like 10 15 min to do the job as long as the bolts comes out easy.
thanks all, my brother came over we did the bed thing wasn't bad
