06-13-2012, 02:29 PM | #1 |
fuel lines
i have an 1984 k10 with dual 20 gallon tanks currently there are not any tanks in the truck but i have 2 new plastic tanks on the way here. since i dont have a prior look under when tanks were hooked up which lines go where? BTW both sending units have 3 lines 2 bigger lines and 1 smaller line. thanks!!
06-14-2012, 07:19 AM | #2 |
Re: fuel lines
This is for a TBI setup , but it will show you the lines running out of the selector valve.
Desert |
06-16-2012, 09:38 AM | #3 |
Re: fuel lines
where do the vent lines run to as i dont have a charcoal can or can the ports on the sending unit be capped off?
06-16-2012, 11:56 AM | #4 |
Re: fuel lines
here is a pic of where they run. and the two big lines are gas and vaper and the little one is the return.
06-16-2012, 12:38 PM | #5 |
Re: fuel lines
Run the vent tubes to the rear of the tuck somewhere or your cab will smell like fuel.
Posted via Mobile Device |
06-16-2012, 03:27 PM | #6 |
Re: fuel lines
how about running them back to rear axle then zip tie them down?
