Old 06-14-2012, 06:48 PM   #1
C5Phil
C5Phil's Avatar
Side view mirror installation question
Just repainted my 70 GMC stepside and bought new 3 hole mirrors and gaskets for both the driver's and passenger's side doors. My question is how does one get the backing plate inside the door aligned so that the gasket and mirror can be screwed to it-- I'm guessing it has something to do with EXTRA long arms- and the help of another person... but if there are any secrets out there I'd sure like to hear them.
These are the type mirrors I'm talking about- second section down on the left side of the page.
http://www.lmctruck.com/icatalog/cb/865w/0077.jpg
C5Phil is offline   Reply With Quote
Old 06-14-2012, 08:12 PM   #2
yuccales
yuccales's Avatar
Re: Side view mirror installation question
Don't take the chance on scratching your paint, get an extra set of arms to hold that plate inside the door. Post some pics of your truck.
yuccales is offline   Reply With Quote
Old 06-14-2012, 08:29 PM   #3
C5Phil
C5Phil's Avatar
I figured it was a two man job--
Here she is minus the bed--
Old 06-14-2012, 08:52 PM   #4
ole dollor
ole dollor's Avatar
yep two arms would be better, nice looking truck...
ole dollor is offline   Reply With Quote
Old 06-14-2012, 08:56 PM   #5
Daddy Brim
Daddy Brim's Avatar
I had the wife help me.
I'm sorry I called you stupid. I thought you knew already.
67 C-20 Custom Camper
68 Nova 396 it does wheelies
2005 Buick Century the one the wife drives
1989 Toyota Tercel to drive when I can't put gas in the first 2.
Daddy Brim is offline   Reply With Quote
Old 06-15-2012, 02:09 PM   #6
yuccales
yuccales's Avatar
That's going to be a good lookin' truck.
Old 06-15-2012, 02:29 PM   #7
Daddy'O
Daddy'O's Avatar
Yes Sir! It's a two person job - my son helped me.
Very nice looking truck!
Cheers - Wayne
Our Shop Build - http://67-72chevytrucks.com/vboard/s...d.php?t=620966
'55 Wagon Build - http://67-72chevytrucks.com/vboard/s...d.php?t=689157
1971 Cheyenne Super Ochre/White LWB 350 Auto - my son's truck "Nancy"
1972 GMC K2500 Custom 4X4 Olive LWB 400 SB 4-speed -"Greenie" - Restoration to begin after the '55
Nothing sucks more than that moment during an argument when you realize you're wrong.
Daddy'O is offline   Reply With Quote
Old 06-15-2012, 08:00 PM   #8
thecatseye66
'68 C-20 396 CST CC
thecatseye66's Avatar
Phil,
I just did this last weekend. There is a hole (an opening anyway) in the inside skin of the door (below the wing window) that is just big enough to get a piece of 1 1/2 inch dowling into (a broom handle might work). I held the plate inside the door (by reaching up from the larger opening below) with one hand (positioned as close as I could on the holes) and pushed and twisted the dowl into the plate to hold it in place. I had to twist the wood so the edge of the door metal would catch into the dowl and hold the plate tight --- but it worked.
I had to adjust each one a few times and used pencils to do minor adjustment and align the threads on the plate to the holes in the door until I could start the screws through the mirror arm and into the plate.
It was tedious but I took my time and made sure it was solid because I had to drill my holes and they weren't exactly right so I wanted to make sure I didn't cross thread anything and ruin something.
Hope that helps--
Chris
68 C-20 396/TH400 CST Custom Camper NOW W/DISC BRAKES
01 Jetta Turbo Daily Driver
84 Yamaha Virago 700 - Alaska to Florida Via Maine & Mexico
thecatseye66 is offline   Reply With Quote
Old 06-15-2012, 08:23 PM   #9
jamie72
jamie72's Avatar
think i drilled my holes and used a piece of duct tape to hold the inner plate on while i got the mounting screws started.
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline   Reply With Quote
Old 06-15-2012, 09:24 PM   #10
C5Phil
C5Phil's Avatar
Thanks for all the info. (and compliments on my truck). I knew a few of you guys had run into the same problem and had some good ideas to solve it-- I'll try this weekend- but most likely I'll get my wife to try and help me out-- that should be a "great time"...lol
Old 06-15-2012, 11:49 PM   #11
thecatseye66
'68 C-20 396 CST CC
I wish I'd thought of duct tape... smart thinking Jamie.
Phil, you have options. Is that color a stock Vermillion in 1970?
Chris
Old 06-16-2012, 10:40 AM   #12
midniteblues
midniteblues's Avatar
maybe a good strong magnet an some tape ,but if there is somebody too help that would be best. good luck
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 06-16-2012, 01:11 PM   #13
C5Phil
C5Phil's Avatar
Thanks to all for the good ideas-- I talked my wife into helping me and we just finished getting them in... we normally are not the best work partners but it went better than I expected....we remain married...
Old 02-22-2015, 08:58 PM   #14
mjs94080
mjs94080's Avatar
Unhappy Re: Side view mirror installation question
Im having the same problem. Is there a vendor that makes these backing plates to put inside the passenger door so I can bolt down the mirrors on the outside?
Or do I have to fabricate my own backing plate?
The driver side door already had 3 holes and a backing plate attached to the inside.
Any advice would be appreciated.
Thanx!
mjs94080 is offline   Reply With Quote
Old 02-22-2015, 09:12 PM   #15
LockDoc
The Older Generation
LockDoc's Avatar
Thanx!
You can get them from any parts vendor. They are reproduced.
LockDoc
Leon
Old 02-22-2015, 10:35 PM   #16
mjs94080
mjs94080's Avatar
Lock Doc,
I got my round side mirrors from LMC and they do not carry the backing plate.
Do you have a link to any of those venders that you are talking about?
LockDoc
Old 02-22-2015, 10:42 PM   #17
ole dollor
ole dollor's Avatar
go to the venders market place on the front page then click on the one you want to look at...
Old 02-22-2015, 11:16 PM   #18
LockDoc
LockDoc's Avatar
Lock Doc,
#1. http://www.classicparts.com/1967-69-.../#.VOqcJrbVrTo
#2 http://www.manestruckparts.com/store...Category_ID=17
eighth item down....
LockDoc
Leon
Old 02-22-2015, 11:27 PM   #19
mjs94080
mjs94080's Avatar
I believe Manes parts is only for 67s.....my truck is a 66.
Old 02-23-2015, 03:51 AM   #20
mjs94080
mjs94080's Avatar
I cant find any leads on this problem anywhere on the internet............
