Easy way to bend 3/8 tubing
I know how to kink 3/8 tubing but i'm having a hard time bending it to a 90 degree with out kinking it. I have tried to normal tubing bender and the plier type which i broke. I need to make two 90's
I built it
Re: Easy way to bend 3/8 tubing
if you have a piece of pipe or maybe a handle off a jack or something you could bend it off that. just dont try for too sharp a turn with it
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness '98 dodge 3500 12v 5sp 4x4. the truck that actually runs |
![]() Join Date: Sep 2011
Fill it with sand first. That will keep it from kinking. Make sure to clean thoroughly when you're done
Posted via Mobile Device |
Look for one of the benders that looks like a long spring. Most of the parts stores sell them. Go slow and be patient. They work really well. I have several styles and this one is by far my favorite.
![]() Join Date: Nov 2003
If you need a sharp 90 you will probably need a 90 degree fitting. The handle benders I have make a nice 90 degree bend but certainly not a tight 90 degree bend.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
The 3/8" stuff is harder to bend than 5/16" or brake lines. Are you using the correct groove in your bender? It will surely crimp in the wrong groove. The best way I have found to bend bigger line is to clamp the stationary handle in a vise so that its more stable. Then you only have to worry about pulling the handle and not stand there hunched over like your trying to open an impossible pickle jar.
Nick Carter 1967 C10 Short bed Fleetside Project Cheap Thrills! 2WD C10 Modern/Performance Alignments Easiest Alignment Ever! |
#7 | |
Found a plastic tubing bender with two handle; a guy let me borrow it from his shop. Worked perfect! Problem solved !
Old school way without getting sand in the tube is fill it with water and freeze it. It does the same as sand, but easier to clean. With the winters in Vermont, I bend 2" pipe for brush gaurds ect. this way
1967 K-20, 1969 K-20, 1970 C-30 dump,1971 K-20 1972 K-20, 1972 C-10, 1968 Grandprix John Deere 350c Dozer, 3414 International backhoe 1972 International 1600 Flatbed |
