I have a 1981 1/2 ton. I have recently replaced the sending unit for the gas tank, and now when I turn my lights on the gas gauge goes to empty. Can anyone tell me why or how I might be able to fix this. I dont do a lot of night time driving, but I dont want it to turn into a bigger problem later. Thanks for your help in advance.
Rey
Life is to short to drive anything else ![]() |
Re: Electrical problem. Can anyone help?
Make sure you grounded the sending unit. Check all the grounds on th front end also.
___________________ 78 ccsb dually 5.3 4l60e http://67-72chevytrucks.com/vboard/s...d.php?t=491551 |
#3 | |
hatzie: Thanks for your reply I'll have to check that in the morning. I remember when I replaced the sending unit the guage still did not mark, when I pulled the cluster out the plug in the back had corrosion on it like the truck had gotten wet or was under water at some time. I think it was under water cause there was also leaves, twigs and dirt all up under the dash. So I replaced the cluster with another one i had . So i'll get back in there toomorrow and check it again. Thanks Rey
Moderator
![]() Join Date: Oct 2008
If it works till you turn on the headlights there's probably a ground problem behind the instrument cluster.
There's a big splice where the Black cluster plug grounds are all connected to a single ground wire from the ground bar under the dash. The Pink/Black cluster power wires have the same type of splice. The panel lamp ground is probably wonky.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
78K & 79C Jimmys
yup sounds like a ground issue
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
