Old 06-16-2012, 06:05 PM   #1
68C20
68C20's Avatar
1968 Lift Kit
Well evidently I have been the victim of wrong parts once again. My rear leaf springs are 52 inches but the center pin is offset. I am trying to achieve a 6 inch lift and run 37x13.50 Toyo Mud Terrain tires. I am willing to replace the entire suspension if need be. I would like to know what have you done to get the lift you want and whose kit did you use or did you have to make something work? I am going to be running the factory K10 running gear.
68C20 is offline   Reply With Quote
Old 06-16-2012, 07:34 PM   #2
68C20
68C20's Avatar
Re: 1968 Lift Kit
Now correct me if I am wrong but you measure the springs eye to eye and not through the curve of the main spring. I have measured from eye to eye and got the 52 inches on the rear springs.
Old 06-17-2012, 06:57 AM   #3
wwj75c30
wwj75c30's Avatar
Re: 1968 Lift Kit
http://www.ntwonline.com/Skyjacker-S...-o-Shocks.html
maybe thatll helpp? but its a 8"
wwj75c30 is offline   Reply With Quote
Old 06-17-2012, 09:49 AM   #4
OLDCHEV4X4
OLDCHEV4X4's Avatar
Re: 1968 Lift Kit
Springs are measured when they are flat, so you have to measure along the curve. From the spring eye to the center bolt. So a 52" spring can be 24/28 or 26/26 etc.
Usually the small dimension goes forward on uneven springs.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 06-17-2012, 09:09 PM   #5
68C20
68C20's Avatar
Re: 1968 Lift Kit
I measured the springs as if they where flat. The springs measure 32/27. Now this makes them 59 inches overall. I have finally figured out that the springs are from ProComp and are listed as 56 inch springs. Is it possible to use these springs with some different hangers or do I need to purchase some correct length 52 inch springs? This truck is currently undergoing a full frame off redo and it probably will not see any serious off road use. It will be used off road just not as a rock crawler or trailblazer.
Old 06-17-2012, 10:39 PM   #6
SunSoaked
SunSoaked's Avatar
Re: 1968 Lift Kit
Pretty sure springs are measured from eye to eye, in a straight line (not along the leaves). I measured my K10 (52 in) and M1008 (56 in) this way.
SunSoaked is offline   Reply With Quote
