Old 06-18-2012, 11:15 AM   #1
AZ71Burban
AZ71Burban's Avatar
Unhappy Sad day.....
Well about a week or so ago i blew a head gasket in my burban.....Im going to have to push it in the back yard till i have the funds to rebuild the motor i hope its not to bad in there.......
{List of Toys}
2005 Nissan Frontier Nismo Edition
1972 Monte Carlo
1971 Chevy Suburban
AZ71Burban is offline   Reply With Quote
Old 06-18-2012, 02:36 PM   #2
zellway
zellway's Avatar
Re: Sad day.....
Not cool man. With this heat it put a load on us. Hope it all works out for you.
Erik
My 69 suburban http://67-72chevytrucks.com/vboard/s...d.php?t=530626
1970 C10 step Project Jiminy http://67-72chevytrucks.com/vboard/s...d.php?t=682647
RUST!? Thats just mother natures way of telling all of us.....MINE!!!!
zellway is offline   Reply With Quote
Old 06-18-2012, 03:10 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
Re: Sad day.....
You may just need the head gasket right now. If it leaked antifreeze into the pan and and it circulated through the engine you will need a lot more than that later, if you let it set too long.
Just my 2¢ worth
LockDoc
Leon
Old 06-18-2012, 09:08 PM   #4
vectorit
What?
vectorit's Avatar
Re: Sad day.....
If you can't touch it for a while, I would drain the coolant and oil.
Blow some air into the heater pipe to blow out all sitting coolant, pull all the spark plugs and then turn the engine over a couple times to blow out any coolant that could be in one or more of the cylinders.
Once that's done, spray a bunch of WD-40 into each spark plug hole.
Finally put a note on your dash warning you that there is no oil/coolant in your engine, since the truck will be sitting for a while you don't want to forget and fire it up with nothing in it.
This is what I would do, since standing water in the cylinder will rust and cause damage to the cylinder wall and rings. Plus if there is coolant in the pan, you want to get it out and not let condensation build up causing more problems.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
