changing back to 67 PS?
The PO put a newer PS set up on my 67, what all do I need from a 67 with PS to put the ram style PS on my truck?
67 Chev SWB, 400 SB .040 over, vortec heads, comp XE268 cam, performer EPS intake, edel. 650 AVS carb, 700R4 |
Re: changing back to 67 PS?
The only pictures I have are 4x4. Why would you want to add back a lot of obsolete parts and leak points. If anything I'd put in a late high effort box tuned for your truck.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
laying low
![]() Join Date: Mar 2001
One has to ask why you would take a step backward like that. Unless you are doing a 100 point restoration maybe? Does the later power sector on it now not work well?
Just thinking about it because it's not the right PS for a 67 and cause the PO hacked up the inner fender with a cutting torch to make it fit and it looks like chit. Just wanted to see what needed to be changed as I've never really looked at a 67 with PS.
![]() Join Date: Jan 2010
the drag link is different other than that everything else is just basically a bolt on from there. a valve that goes on the end of the drag link (you can buy new), a cylenbder ram (you can buy new) a regular power steering pump (you can get used, new or you already have one), and the steering hoses (im trying to find a place to get new ones or you can get them made). the hardest part is getting the drag link and good hoses. you also need a special pitman arm which is specific to this and may be hard to find but if you find the drag link chances are they will have the arm to.
I have a 67 if you want to check out the steering setup, i'm pretty close by. Send a pm with your number. Allan
Ecklers Corvettes has the rebuild kits for the control valve and the cylinder. They're about $20 for each kit now. My '67 has the Ram Assist steering also. I wanted to keep it on there because you don't see many at all with it. I found the hose kit from a guy in Texas. Just can't think of the name right now. $72 for the set. Just over a $100, some fresh black paint and she's good as new.
Ecklers also sells the control valve and the cylinder, $140 each. Not sure if they are the exact ones but they sure look like it. The rebuild kits I bought worked perfect. |
#9 | |
Come to think of it, I did have to have a new high pressure line from the pump to the control valve made up. That line had the wrong end on it.
My notes show it's an Omega #4051, but I couldn't locate one so I had one made.That was another $75. |
