6 to 5 lug conversion
i have a 12 bolt rear with 6 lug drum brakes. I need to convert it to 5 lug. I've seen kits as shown below to convert to disc brakes but dont know if i need to get new axles or not. i need the cheapest solution. thanks
Re: 6 to 5 lug conversion
Are you wanting to swap to discs, or can you keep drums? I am converting my front to discs right now and took my drums and axles to a machine shop and had them re drilled to 5x5, cost me about $75 and 10 new studs.
Posted via Mobile Device |
i wanted to but wasn't sure how to do it as cost effectively as possible
60-66 Nut
If you have a '64 to early '70 12 bolt, all you have to do is either buy the 5 lug conversionn axles, or have your axles plugged and drilled to 5x5. Then you will need the drums for a '71 to mid 70's truck with the 2" wide shoes. Before you spend any money on having your original axles plugged and drilled, be sure the bearing surfaces are in good useable condition. After 40-50 years of use, many of them are not in good condition.
#5 | |
60-66 Nut
Sorry I misunderstood.
If you're wanting rear discs, I sell 3 different rear disc conversion brackets for the 5x5 wheel bolt pattern. There are links in my signature line.
