Old 06-20-2012, 11:10 PM   #1
bilfman
bilfman's Avatar
Hood lifting, some advice please
Hi all,
I got my hood lifting at the back by the windshield. Im sure this is a common issue, but I am unaware of a fix. Any suggestions appreciated. My thought is a weak spring, I put a set from another truck, but have the same issue. Could be another weak set, but thought I would tap the forum wealth before taking another step.
I have included a pic, not the best of the issue, I can get another on if a clearer view is needed.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205
1971 GMC 3/4 Ton 4X4
bilfman is offline   Reply With Quote
Old 06-20-2012, 11:57 PM   #2
dmartin1
dmartin1's Avatar
Re: Hood lifting, some advice please
i have the same problem.ive adjusted the hood hinges as much as possible and replaced springs with other junkyard springs and it still sits up.
my next step is to just buy new hinges and springs and see whats up then.
best of luck!
1969 Shortbed in progress
1982 short step, few suspension and motor upgrades.getting a 468
1978 Shortbed fleet side bonanza fully loaded
1978 k20 Silverado loaded.currently engine-less
1989 k10 suburban 9" lift
65 nova
And more
dmartin1 is offline   Reply With Quote
Old 06-21-2012, 12:51 AM   #3
tater502
New hinges would be the right way to fix it.
I fixed mine the cheap way and put some washers between the hinge and hood(front bolt).
http://www.autobody101.com/content/a...nel-alignment/
tater502 is offline   Reply With Quote
Old 12-14-2013, 06:39 PM   #4
520CheyenneK10
Do you have a pic of the hinge with the washers please. I have had it and am looking for any solution(s). Thanks
520CheyenneK10 is offline   Reply With Quote
Old 12-14-2013, 09:38 PM   #5
tater502
Before
After
Old 12-14-2013, 09:51 PM   #6
520CheyenneK10
Tater I tried that and it was still up too much for my picky self . I just posted a thread on what I did. Thanks for the pics though.
Old 06-21-2012, 01:44 AM   #7
juiceman650
juiceman650's Avatar
Hinges definitely help. Swapped em on mine and they helped a lot.
1975 Chevy Cheyenne w/ v8 350 and TH350
Siverado interior
Fleetside bed
aka "The Beast" aka "Cheyerado"
juiceman650 is offline   Reply With Quote
Old 06-21-2012, 06:54 AM   #8
xrcr
X3 on hinges ,New repop ones are reasonably priced
xrcr is offline   Reply With Quote
Old 06-21-2012, 05:50 PM   #9
76stepsidechevy
Do they just wear out of what the deal ? My hood does the same thing but the hinges work nice and smooth. If I push the rear corners of the hood down it holds until I drive it again. Do the springs even hold the hood down when its shut?
76stepsidechevy is offline   Reply With Quote
Old 06-21-2012, 07:19 PM   #10
bilfman
bilfman's Avatar
Mine does just as you described.
Old 06-21-2012, 07:52 PM   #11
brian's 77
I read a writeup a while ago where 2 people fixed the issue. One guy pushes the hood up and the other guy loosens the bracket that bolts onto the fender. Then that guy pushes the hood higher, sort of like hyper extending it and then the other guy tightens the hinge back. It worked for me.
brian's 77 is offline   Reply With Quote
Old 06-22-2012, 03:52 PM   #12
xrcr
my problem was the rivits/hinge plates being worn.
Old 12-14-2013, 06:43 PM   #13
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
make sure that y9ou keep the hinges well lubed it will make em last longer and keep em free
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 12-15-2013, 01:39 PM   #14
cool68
use of Sea Foam Deep Creep lubricant might help
cool68 is offline   Reply With Quote
Old 12-17-2013, 07:45 PM   #15
Love2Ride450
I have dealt with this on numerous occasions on many GM vehicles. The answer was posted a few posts back. The hinges need to be dropped in the back, or raised in the front. Loosen the back bolt that goes into the fender, have someone push up on the hood until the hinge rotates downward in the rear, retighten the bolt and check. If this does not do the trick, or it is already bottomed in the rear, try moving the front upward. The hinges "cam over" when they reach the bottom. When they are too high like that in the back, it's because they aren't camming over. That's why adding the washers under the front helps, it's making the hinge cam over.
Good luck, Hope it helps!
Love2Ride450 is offline   Reply With Quote
Old 12-18-2013, 09:57 AM   #16
trout
Loosen the bolts that hold the hing to fender they are slotted
Edited by staff
trout is offline   Reply With Quote
