06-20-2012, 11:57 PM | #1 |
cowl vent leaking
i recently bought a 66 swb(ill post pics later) trying to get all the little stuff fixed on it before i start really fixing it up, it seams the cowl vent leaks when it rains, in between the vent and kick panel. is there a seal there?
06-21-2012, 12:48 AM | #2 |
Senior Enthusiast
Re: cowl vent leaking
The drain in the bottom of the vent housing is probably clogged up with leaves and debris. Normally water just runs out the bottom, so it should never reach the level of the vent opening. If you have access to a compressor or a weed blower you might try closing the vent doors and blowing up through the bottom of the drain to clean the clog. Or you can remove the vent assemblies and try vacuuming out the bottom of the housing.
Here are a couple photos of the drain. These are shots of the passenger side looking over the right front tire:
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
06-21-2012, 01:08 AM | #3 |
Hey Mark for years I thought mine were leaking, kept resealing them...turned out to be the rain gutter in the very front middle of the cab leaking down to the windsheild seal and running down to each side rolling out at the kick panel, so he might want to check that as well.
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
06-21-2012, 01:19 AM | #4 |
Senior Enthusiast
Good point, I wouldn't have thought of that.
06-21-2012, 06:54 PM | #5 |
already checked for trash in the drain not sure what you mean about the windshield.
06-21-2012, 07:54 PM | #6 |
Top of the cab at the edge is the rain gutter that runs all the way around the cab, that is where the top is welded on to the outer perimeter, the factory seals this with cauking, over time the cauking starts to crack and leak down into the area just above the windsheild, it can go one way or both depending on where the leak is, all the old cauking needs to be removed with either sand blasting or wire wheel, painted with an epoxy primer and resealed with the proper sealer.
if it is in fact leaking there. run a garden hose on the top so that it is just a slow trickel and watch inside the cab.
06-21-2012, 08:03 PM | #7 |
ahh gotcha, thats why some of these rust out there? im guessing its goin inside the a piller and running under the dash?
06-21-2012, 08:08 PM | #8 |
Correct..!
06-21-2012, 08:09 PM | #9 |
i bet thats where its leaking thanks man!
