Old 06-22-2012, 01:46 PM   #1
bestchevyfan
What= ????????????
I have an '84 six cylinder 250. I have a power steering pump but no bracket. What can I get a bracket off of that will fit properly. I found a complete bracket for a mid 80's GM/Chevy 250 six cylinder, but they said it was for a six cylinder with an integrated head. Does any know what this is? Any information is appreciated. Thanks.
bestchevyfan is offline   Reply With Quote
Old 06-22-2012, 08:11 PM   #2
big10ratrod77
big10ratrod77's Avatar
Re: What= ????????????
that was chevys briliant idea of makeing the head, intake, and exhaust manifold one peice.ever six from like 76 up has this head(perty sure it was around then)eny ways your truck has it and you powersteering pump should bolt right up
77 chevy BIG 10 350/sm465/12bolt w 3.73 bout 240 horse power NO power steerin
79 chevy 1/2 ton 250/three on the tree/3.08s soon to get built 250/floor shift conversion/3.08s
81 mercedes 300d 25 MPG
77 chevy BIG DOOLEY 454/sm-465/14 bolt 4.10s "fully loaded"
73 plymouth duster 225 slant six/230 3 speed/8 1/4 trying to acheve 300 horse six http://www.cardomain.com/ride/3135091
'77 chevy trucks. built to stay tough.
life is short build a hot rod
big10ratrod77 is offline   Reply With Quote
Old 06-23-2012, 07:05 AM   #3
D13
D13's Avatar
If you have an 84 then you will have an integral head. Quick check - take the top of the engine air cleaner. If you have a 2 throat carb is is an integral head - all non-integrals have 1 barrels and only 250's after 1981 have 2 barrels.
Other things to watch:
GM changed the connection at the steering box at some point. Assuming you have a power steering gear, you need to make syre you get the correct style hose ends. BTW six cylinder hoses are different; I'm not sure if V8 pumps have the return line oriented correctly, or if the V8 hoses are long enough.
You need to make sure the pump mounts mount up to your brackets, there are 4 mounting pads on most pumps but only 3 will be drilled And the studs on the rear come in different patterns IIRC.
Brackets are often available on evilflay under $50. They ONLY fit integral heads, so the're not real popular. Earlier brackets which will not fit integrals are much more expensive.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 06-23-2012, 08:58 AM   #4
100%Chevy
This is a 75,250 with integrated head and P.S. bracket-
Mike./
100%Chevy is offline   Reply With Quote
