06-24-2012, 11:34 AM | #1 |
Radiator problems
Recently got my new core support, radiator, and radiator mounts. For some reason the lower mounts will not work with my core support unless I do some cutting and even with the lower mounts not even in the radiator still sits 1/2" or more too tall. Anybody else run into problems like this?
69 SWB Fleet/72 running gear Currently under frame-off 67 SWB Stepper smallwindow |
06-24-2012, 01:14 PM | #2 |
Re: Radiator problems
i'm not sure what year you are working on but trimming is necessary if you are running a bigger rad in a 67-68 core support,the later ones are wider in this area.had to trim mine
06-24-2012, 05:16 PM | #3 |
Cut mine to put my new 4 core in no problem.
I'm sorry I called you stupid. I thought you knew already. 67 C-20 Custom Camper 68 Nova 396 it does wheelies 2005 Buick Century the one the wife drives 1989 Toyota Tercel to drive when I can't put gas in the first 2. |
06-24-2012, 10:48 PM | #4 |
It's a 69-72 support but even if I cut the support to make the lower mounts fit, looks like its still gonna be way too tall. Might be wrong but i didn't want to cut a brand new core support if it still wasn't gonna work
06-25-2012, 11:41 AM | #5 |
Any pics or suggestions what or where I need to trim?
06-25-2012, 11:56 AM | #6 |
I am a Referee of life.
What radiator,supports and core?If you post this info we can better answer your question.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
06-25-2012, 02:53 PM | #7 |
69-72 core support, 4-row "direct replacement" aluminum radiator and upper and lower mounts all from classic industries. Don't have part numbers but I can get them when I get home from work if that helps
06-25-2012, 03:23 PM | #8 |
Old Skool Club
My '69 came with a 4-row core radiator. I got a replacement 4-row core unit from a radiator shop. It dropped directly into the rubber mounts w/o any issues. I had already replaced the cab and radiator support mounts, so I'm no help at all, am I?
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
