Gutting Doors - Need Help
Hey Gents!
How's it going. I scored some perfect factory 91 suburban doors (Manual Mirrors), and I am disassembling them so that I can paint the jambs because the paint/prep seems to come out much better that way. I will just prime the outside for now because it will be another year before I'm ready to paint the whole exterior. Now to my question: I managed to get everything out, but I'm having trouble removing the exterior handle. I removed both 3/8 bolts, but their is a latch and rod preventing it from coming out. How do I get this handle off? Thanks- BLUE SQUARE Last edited by BLUE SQUARE; 06-27-2012 at 12:28 AM. |
![]() Join Date: Oct 2011
Re: Gutting Doors - Need Help
i pulled mine out a ways and had a buddy use a punch and a hammer to tap the roll pin out while i held on to it. didnt take much...
88 3+3 454 400 205 410 drw to srw still in pieces 90 3+3 350 400 205 410 srw 84 1/2 ton lb 6.2 4x4 parts truck |
Home Built '87
You can also:
1. remove the two bolts just like you did 2. push the black door release button all the way in and wiggle the handle free of the hole in the door 3. get a light and look in the door along the outside edge until you see the rod that is still attached from the door handle to the inside release mechanism 4. get a long screwdriver and push the clip down that is holding the bottom of that rod to the door release mechanism....you will not need to remove the clip totally, just about half way until the rod comes out of the clip You might need to use pliers or some force with your hand if you can reach that rod but it will come out of that clip. Then you just lift the handle and the rod will come out with the handle from the bigger hole near the door edge on the door exterior. Hope it works for you. Antigov's way will work as well, the rod stays inside the door that way.
Gordon 1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424 1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833 Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969 |
Thank you Gentlmen.
I actually used a long flat head screw driver to slide down the clip on the latching mechanism like Gordonr1973 suggested. It was a breeze. Now my doors are gutted. I will start preping them for paint today. I also removed the rubber impact strip which came on these 91 suburban doors too. Man that glue is tough to get off. I razored it down as far as I could without damanging the surface. Does anybody have a good technique for removing this double side adheasive??? Thanks again, BLUE SQUARE |
Goof off or goo-b-gone will remove the adhesive.
It takes a bit of doing though... Posted via Mobile Device
I read somewhere that WD-40 or brake cleaner work well for this.
The brake cleaner might be the ticket. We'll see how it goes. |
#7 | |
Home Built '87
You might be able to get a rubber adhesive removal wheel (same idea as a wire brush wheel that can be used in a drill) at an autobody supply store that will take that stuff off without damaging paint.
Brake fluid will take off paint.
I've never had good luck with WD-40 Posted via Mobile Device
In the Forgotten far North.
![]() Join Date: Jul 2007
3m 08498 quart size metal jug is an excellent adhesive remover. Use it at work all the time
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
