getting P0120 & P2135 codes
Wondering if I have the correct stuff for my motor for the DBW setup. I am getting P0120 & P2135 codes
PCM is programed to be an 06 5.3 SERV. NO. 12589463 Throttle Body is 1257080rme75- ![]() TAC module 12573059 ![]() There are no #'s on the pedal ![]() |
Re: getting P0120 & P2135 codes
'06 should have the all plastic pedal.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
meowMEOWmeowMEOW
yup, you'd need the molded plastic one. I had the exact opposite problem when I did mine, got the new one needed the old one. Ls1Nova saved me on that one!
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
DAMN! Someone told me I could try to reprogram my PCM to be an 05 and use that pedal/TAC. Do you think it would work? I was told I had an 06 motor, but with the return and reg on the fuel rail and the plastic fuel rails in previous posts everyone thought it was an older engine.
Is the TAC module the same for an 06? |
I think there are different part numbers for them. I have an '06 and can check later tonite and tell you if it's an '06 or not.
#6 | |
I found this pedal on Ebay http://www.ebay.com/itm/2006-2007-Si...ed6d66&vxp=mtr |
The TAC module you have matches your pedal. It's probably because you have it programmed as an "06. My 2006 TAC has a part number 12590008, so you could either try changing it in the tune, or get an '06 TAC and pedal.
#8 | |
P02135 says throttle/pedal position sensor/switch "A"/"B" voltage correlation If not the harness then could it be the throttle body? When I turn the key on you can hear it click the servo on the throttle body twice. Posted via Mobile Device |
I read that, and tried pulling in the wires to see if they stretch and show white, but did not notice any. Maybe I will pickup some wire and replace the wire 12" back. I could try to test it on a multimeter, but don't have any clue what I should be getting @ each pin.
Ephesians 2:8
osaltyone, did you ever solve this issue?
72 Suburban making it mine My 79 C10 story 79 C10 LS swap 94 LS swapped Daily Driver Tahoe Limited Instagram - @piersonclassics 83 K20 Farm Truck Build |
yep, I swapped my throttle body out for another and it worked fine. Something was up with the old one I guess.
