Old 06-28-2012, 12:43 AM   #1
ChuckW
ChuckW's Avatar
Shoulder Harness kit? 66C10
66 C10 with weld nuts installed for shoulder harness'. I've been searching for a retractable lap belt/shoulder harness installation. Saw one at a Santa Maria, CA. custom show a few weeks back so I know it exists. My bad in that I did not write down any info. Has anyone installed or located any kits? Would be greatfull for any info! And Thank you!
ChuckW is offline   Reply With Quote
Old 06-28-2012, 05:29 AM   #2
T2vigil
T2vigil's Avatar
Re: Shoulder Harness kit? 66C10
I installed a couple from Julianos. The kit had everything I needed.
T2vigil is offline   Reply With Quote
Old 06-28-2012, 11:31 AM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I've seen a 4point race harness, but other than that only lap belts.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 07-01-2012, 11:09 PM   #4
ChuckW
ChuckW's Avatar
Thanks guys.... T2vigil, Did your truck have OM seat belts? If so, where you able to use the original OM attach points with Julianos? I chatted with Cust Ser.@ Julianos and they could only give me info on 67 and later. I have OM lap belts and the weldnuts OM installed in the posts. Julianous looks like a nice easy install.....(If I can use OM mount points)...
True?
Old 07-02-2012, 11:04 AM   #5
CRGRS 66
CRGRS 66's Avatar
There was a thread on adding shoulder type seatbelts to our trucks, most kits come with a bracket that has a tapped hole to take the bolt to hold the shoulder harness in place, no welding needed, you just need long arms!
If I find the thread, I will post it up for you.
Craigerrr
My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709
CRGRS 66 is offline   Reply With Quote
Old 07-02-2012, 11:09 AM   #6
CRGRS 66
CRGRS 66's Avatar
actually, have a look at this one, the bracket kit is 10.95, I believe it is easy to reach up and hold the bracket in place on the passenger side, a little tricky on the driver side due to the gas tank. a friend with long skinny arms, or a coat hanger and some clever bending might also do the trick
http://www.seatbeltplanet.com/seatbe...cts/25/view/63
Craigerrr
Old 07-02-2012, 12:53 PM   #7
T2vigil
T2vigil's Avatar
Chuck, I have a 64 and it did not have any existing holes. I utilized the measurements in an old post for the shoulder strap location. I just found a spot on the floor that would work. Passenger side was the easyist, long arms work or in my case I used long paint stick. Once you get the bolt started in the bracked all is good.
Old 07-02-2012, 02:37 PM   #8
ChuckW
ChuckW's Avatar
Thanks for the info!
Old 07-02-2012, 06:47 PM   #9
ljackson
ljackson's Avatar
Here is what we did on my son's truck.
http://67-72chevytrucks.com/vboard/s...d.php?t=476066
Father and son built. Driven daily since 2012. 283, 3 speed. Mostly original. '81 PS and disk front. Fuel tank relocate.
Maintenance, repairs and upgrades on his dime now.
http://zacks64longfleet.shutterfly.com/
Higher res. photos in my gallery.
ljackson is offline   Reply With Quote
Old 07-02-2012, 06:56 PM   #10
CRGRS 66
CRGRS 66's Avatar
Thanks for posting the link, great info, every little bit helps!
Craigerrr
Old 07-02-2012, 07:07 PM   #11
ChuckW
ChuckW's Avatar
Thanks all! Good info! My 66 has all the OM mount points including the shoulder harness post mount. Based on all of your pics I should be able to utilize them....
