06-28-2012, 10:50 AM | #1 |
Cleaner windows!
Just thought I'd share a little trick I discovered while driving around my last truck...
If any of you guys have hard water spots on your trucks you know how much of a pain in the ass they can be to clean. I had several large spots on the top of my sunroof that would just not go away. Finally I hear about a little trick some of the guys had been doing and it worked wonders. Steel wool. 0000 grade steel wool is soft enough that it won't scratch the glass, but it takes off all kinds of crap. I use it with a bit of rubbing compound, but I have heard that vinegar is another alternative. You won't believe how much nicer it makes your truck look even if you don't think the windows are that dirty! You can pick up the steel wool at almost every hardware store. I've even seen it at my local walmart. My fiance's parents even used it to clean their kitchen windows haha |
07-03-2012, 10:55 AM | #2 |
Re: Cleaner windows!
I use an SOS pad and some Bar Keepers Friend (its kinda like Comet)works great allso.Then I have a bottle of 75/50 mix of water/ vineger for inside of windows
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
07-03-2012, 04:21 PM | #3 |
I have always used 0000 steel wool and Chrome Polish and it works great. Vinegar has never worked for me.
1969 Chevy C/20 Project- Re-built 350 (more info to come) http://67-72chevytrucks.com/vboard/s...=1#post6377987 1977 Chevy K20 Silverado Camper Special- Future Project 1969 Chevelle Malibu 2011 Yukon XL Denali 2013 VW Passat TDI (Daily) |
07-11-2012, 06:30 PM | #4 |
good tip,works great,thanks.
07-15-2012, 02:48 PM | #5 |
i use the windex vinegar. not many of us still have the old glass windshields, so for acid marks or hard water, steel wool is a bit harsh. a little clr works great for hard water marks and the white polishing compound from turtle wax works great or acid etching. 3m, mequires, and a lot of other companies, make a kit for polishing windshields thats great for taking out fine scratches and wind pits.
is it done yet? |
07-27-2012, 10:09 AM | #6 |
I meant 75/25 sheesh
