06-28-2012, 05:47 PM | #1 |
1969.C10 c-notch and 2inch blocks..15s ok?
69 C10 ok im going to install my c-notch this friday and thinking about 2inch blocks too...will i have scrub line problems with 15" steel wheels? thanx for the help
06-28-2012, 05:49 PM | #2 |
Truck Enthusiast
Re: 1969.C10 c-notch and 2inch blocks..15s ok?
you should be just fine. did a '69 with a 7" rear drop, 15" wheels with no issues.
how low are you already?
'85 swb |
06-29-2012, 01:37 AM | #3 | |
1.5" blocks max w/15" wheels. Even then, you need to ensure the u-bolt tips are trimmed so they are basically flush w/the retaining nuts. If the tire goes flat, there is still enough rubber there to keep the u-bolt nuts from digging into the road surface unless the tire comes completely off the rim.
06-30-2012, 06:53 PM | #4 |
Grandpa in the rustmobile...
Im running a 2" block and 15 rally
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
06-30-2012, 11:22 PM | #5 |
Happy to be here
No one said it can't be done. Its just not safe in the event of a blow out.
07-01-2012, 01:03 AM | #6 |
and in the front i have 2.5 drop spindles and bags ...to get the ride hight i want i have to run low psi and that makes for a bad ride...what are my options to stay low and have the right psi too....from looking around this site i can cut down my bag lower cups so thay are only 1inch??? this true??? and also if i cup the lower A arms then i can have more psi in the bag im guessing and still be low??? thanx for the help
07-01-2012, 09:52 AM | #7 |
A guy with a truck
Yes, but 1 5/8 is generally the shortest people go on the cups before rubbing issues arise. Cupping/plating is also an option
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
07-01-2012, 10:36 AM | #8 |
what is cupping /plating?
07-01-2012, 11:08 AM | #9 |
Happy to be here
He is referring to cupping the lower A-arms and plating them for strength. This will get you lower ride height and allow you to raise your bag pressure.
07-01-2012, 11:54 AM | #10 |
cool cool and the max for that is 2inch cups?
07-01-2012, 11:55 AM | #11 |
and if i cup my lower arms do i need to have the bag cups on too or do i just let the bag float in the lower arm?
07-01-2012, 01:55 PM | #12 |
A guy with a truck
Get a piece of 3/16 plate. Trim to fit/weld to the bottom of the arm. Get a piece of 8" pipe. Weld in place of the coil spring pocket. Drill a hole on center to mount the bag. Search the forums for pics- quite a few members have done it...
