Old 06-27-2012, 03:34 PM   #1
Luis_gz06
Luis_gz06's Avatar
72 A/C Wiring Harness?
Hi everyone. Anyone know where does the long orange a/c wire plug into the fuse box? Also, does the wire run on top or bottom of the radio and on top along with the main harness? Any help is appreciated. Thanks!
1972 Chevrolet Blazer 4x4 (Almost done stay tuned)
1970 Chevrolet Pickup Longhorn CST/20 (SOLD)
Luis_gz06 is offline   Reply With Quote
Old 06-29-2012, 01:01 AM   #2
Luis_gz06
Luis_gz06's Avatar
Re: 72 A/C Wiring Harness?
ttt
Old 06-29-2012, 07:09 AM   #3
Daddy'O
Daddy'O's Avatar
If your speaking of the orange wire that goes to the AC blower motor relay then it plugs into the CIG terminal in the fuse block. I am not 100% sure of the factory correct routing of the AC harness. My assembly book is at home - and I am not. Hopefully someone can verify the routing for you today.
Cheers - Wayne
Our Shop Build - http://67-72chevytrucks.com/vboard/s...d.php?t=620966
'55 Wagon Build - http://67-72chevytrucks.com/vboard/s...d.php?t=689157
1971 Cheyenne Super Ochre/White LWB 350 Auto - my son's truck "Nancy"
1972 GMC K2500 Custom 4X4 Olive LWB 400 SB 4-speed -"Greenie" - Restoration to begin after the '55
Nothing sucks more than that moment during an argument when you realize you're wrong.
Daddy'O is offline   Reply With Quote
Old 06-29-2012, 07:51 AM   #4
rsavage
rsavage's Avatar
Assembly Manual indicates the orange wire from the A/C harness is plugged into one of the "ignition unfused" terminals on the fuse block. HOWEVER, the Chassis Service Manual Four Seasons A/C wiring schematic shows the 12g orange going to the "cig" terminal and replacing the fuse with a 25 amp. The 20g grey wire for the control lights goes to the "panel lights" terminal.
Assembly manual shows the wire going across the bottom for your control connections and then up across the top and around the dash hole.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 06-29-2012, 04:16 PM   #5
Luis_gz06
Luis_gz06's Avatar
Thanks! Which dash hole?
Old 06-29-2012, 04:23 PM   #6
rsavage
rsavage's Avatar
The large hole that the instrument panel goes into. Once it gets over to that area it goes up and above like the main harness does using the same bendable wire clips that are up there.
1961 C1 Corvette
2021 Durango RT 5.7
Old 06-30-2012, 11:40 AM   #7
Luis_gz06
Luis_gz06's Avatar
Thanks alot! Did not understand at first about the dash hole. Does the glovebox light harness run the same on the top with the main harness? Thanks!
