Old 06-29-2012, 08:01 PM   #1
wwj75c30
wwj75c30's Avatar
will 33x12.50s fit?
i waas wondering if 33x12.50s would fit on my 75 c30 i have 3" coil spacers on it it sits alil higher in back. the stock tires look so tiny on it so i wanna make it look beefy lol im pretty sure theyll fit in the back but will they rub in the front?
wwj75c30 is offline   Reply With Quote
Old 06-29-2012, 08:10 PM   #2
Rubble
Re: will 33x12.50s fit?
Yeah,you might rub on the front.Back should be ok.I have 33s on my k20 with a 4" lift and the front is still fairly close,but that's with 10" wide rims too.
1977 Chev C30 454/465/14ff DRW
1974 Chev C20.350/465/14ff
" Rock n Roll ain't noise pollution"
Rubble is offline   Reply With Quote
Old 06-29-2012, 08:11 PM   #3
wwj75c30
wwj75c30's Avatar
so you think i should be fine? should i trim alil? it sits high as a stock height 4x4
Old 06-29-2012, 08:25 PM   #4
Rubble
You might be ok with 8" rims.Give it a try,nothing but fear and common sense holdin you back eh......
Old 06-29-2012, 08:52 PM   #5
wwj75c30
wwj75c30's Avatar
i have the stock rims i think there like 6.75 wide or something
Old 06-29-2012, 11:10 PM   #6
wwj75c30
wwj75c30's Avatar
actually new idea here guys would 36" goodyears fit? with a 3" body and 1" block in back
hopping itll be 6" lift in front and 4" in the back but itll sit level
Old 06-30-2012, 12:13 AM   #7
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Guys you forgot it's a dually. The front might rub. But a little trim can fix that. The rear, a 12.5 inch wide tire will not fit on 7.5 inch or smaller wheel, not only that but the tires will most likely rub together.
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 06-30-2012, 12:55 AM   #8
wwj75c30
wwj75c30's Avatar
im gonna try to get a set of 33x10.50s and run a spacer inbetween the wheels
Old 07-02-2012, 01:57 AM   #9
Number21
Number21's Avatar
I've got 33x12.5s on my stock height '73 and they fit just fine. No rubbing.
'73 K20 Cheyenne Super Camper Special 350/TH350/NP205 sittin' on 33's.
You can set my truck on fire and roll it down a hill,
and I still wouldn't trade it for a Coupe de Ville.
Number21 is offline   Reply With Quote
Old 07-02-2012, 04:55 AM   #10
wwj75c30
wwj75c30's Avatar
but mines a 2wd lol
75 c30 silverado drw 454/th400hd d70 soon to have d60 up front
73 c20 custom deluxe sm465 14bff parts truck
