Gone Fishing
Trans dipstick ?
How are yall bolting the trans dipstick? My block has the hole blanked
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop ![]() 2022 Hyundai Tucson Limited 2019 Chevy Traverse Redline Edition Wifes Ride Build Thread http://67-72chevytrucks.com/vboard/s...=1#post3483616 |
Truck and auto performance nut
Re: Trans dipstick ?
maybe that's whats wrong with mine...didn't seem to line up. Figured I'd just need to do some bending... or something creative.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
You need a LS style 4L80E dipstick tube, & you need the factory style "double studded" bellhousing bolt & the 8x1.25mm nut.
I was able to bend the tab so that it would bolt onto the back of the head.
Thanks clinebarger...this one's a Hughes steel tube dipstick. Definition shows - "Transmission Dipstick, Locking, Bellhousing Mount, Chevy, 4L80E"
Now that I know where it probably "should mount"...maybe I can inflict a bend or two in just the right spot to line up its single mount point. I'll need that stud and nut for it tho.
#6 | |
Bending the Hughes mount again wont help...It's made to bolt to the missing bellhousing bolt. |
oh wow...OK I'll look for an OEM setup. And I thought I was getting the right thing...dang.
so this one wouldn't be accurate either?
So any more info on this subject ? I'm swapping a lq9 /4l80e into my 69 c-10 and didn't get a dipstick tube with my tranny . Thanks in advance !!
meowMEOWmeowMEOW
Cline is right...GM is the only one who does this right for the 4l80e. Most places will try to sell you the 4l60e stick, or a universal one. Almost no universal will work because 98% if them do not have the locking top, with exeptions like the REALLY expensive stainless ones from Lokar.
I ended up getting the dipstick tube from my gm dealer, although at the time he couldnt' find a dipstick in stock. I ended up modifying one from a 4l60, cut and welded to the right level. I will replace it this summer though, its a little ghetto. My dealer doesn't stock much, but he will usually give out the part #'s (he doesn't care much about customer retention lol) and I'll buy the stuff from gmpartsdirect or similar.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
#10 | |
Collector of Projects
I bought a Lokar 4L80e dipstick in black.... Ended up buying a stock GM part. My truck isn't Lokar quality and with the factory heater box, I couldn't find a place I liked to mount the Lokar one... Stock part should work fine for me...
$24.24 15832205 Tube - dip stick tube $31.28 15183801 Indicator - dip stick : New PN 15791230 $1.98 1259475 - Dipstick tube seal 4L80e $2.63 15724226 - Stud prices are from www.gmpartsdirect.com Last edited by mcmlxix; 02-08-2013 at 04:28 AM. |
[QUOTE=mcmlxix;5875328]I bought a Lokar 4L80e dipstick in black.... Ended up buying a stock GM part. My truck isn't Lokar quality and with the factory heater box, I couldn't find a place I liked to mount the Lokar one... Stock part should work fine for me...
$24.24 15832205 Tube - dip stick tube $31.28 15183801 Indicator - dip stick : New PN 15791230 $1.98 1259475 - Dipstick tube seal 4L80e $2.63 15724226 - Stud prices are from [url]www.gmpartsdirect.com Yea - I went there yesterday and typed in that part number for the dip stick and it said indicator . I was thinking , indicator ??? Looks like i'm the dipstick now ![]() |
