07-02-2012, 04:07 PM | #1 |
wtb rear sport bumper mounting brackets.
1972 C 20 with rear leaf springs. Need sport bumper mounting brackets.
07-04-2012, 01:38 PM | #2 |
Re: wtb rear sport bumper mounting brackets.
come on no one going to help me out. can i use coil spring brackets. or at least part of them?
07-04-2012, 08:29 PM | #3 |
If you have a long bed you will probably be able to use the inner brackets from a coil spring truck. The outer brackets will work.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
07-04-2012, 08:37 PM | #4 |
67-72 parts collector,…
07-04-2012, 08:48 PM | #5 |
Keith are you saying this will work on a 2wd leaf spring truck. I too been looking for a set.
DREW67 |
07-04-2012, 08:59 PM | #6 |
Classic Parts lists these and 2wd brackets.
As far as I know there are only 2 different sets of rear sport bumper brackets. I'm guessing since all 4x4 trucks are leaf spring. I was hoping someone else would chime in.
07-05-2012, 03:33 AM | #7 |
Moderator
If you have a 4X4 or a SWB it takes one size of rear bumper brackets.
If you have a stepside, SWB with coil, LWB with coil, LWB with leaf, or a longhorn, it takes the other size.
2018 Chevy Crew Cab 2006 Impala SS 1965 Plymouth Sport Fury 1970 Chevy Longhorn
70 Longhorn CST Build Adding an AM/FM Decal |
07-05-2012, 08:16 AM | #8 | |
DREW67 |
07-05-2012, 01:12 PM | #9 |
"Junkyard Dog"
Where does the Sub outers fall into the equation?
72 C-10 Cheyenne Super LWB, Vortec 427,TH700, 3.73 posi, tach, tilt, AM-FM,Frame off in process. http://s289.photobucket.com/albums/l...t=7eae161e.pbw 88 Monte Carlo SS bought new only 10k miles. 73 Chevelle SS 454 had since high school. 74 Camaro Z28 350 AT numbers matching, Black on Black. 73 El Camino SS 350 4sp. 70 Chevelle SS 396 4sp, number matching with LS6 454 69 Chevy C30 Car Hauler 86 K20 383 4sp 4" lift frame off restoration. http://s289.photobucket.com/albums/l...t=1b1082d3.pbw |
07-05-2012, 02:09 PM | #10 |
Thank's the help was needed. I did not want to put the old HUGE bumper back on. Also yes it is a long box. Thank's again.
07-05-2012, 08:01 PM | #11 |
Sub outer brackets are the same as for the trucks.
Jim
07-06-2012, 01:08 PM | #12 |
"Junkyard Dog"
So..are the outers the same regaurdless if it a PU, Sub, or BLazer and the inners are the only difference?
07-06-2012, 07:20 PM | #13 |
Outer brackets are the same regardless. On the 72 Blazers and Burbs, the frame was used for the inner brackets.
Jim
07-06-2012, 07:36 PM | #14 | |
I know my old '69 burb did.
07-15-2012, 03:47 PM | #15 |
ttt
08-27-2012, 09:19 PM | #16 |
Terry,
What did you use that worked? I have a 1970 c 20 longbed with leafs and want to install a sport chrome bumper... was it a bolt on or did you do any mods? Did you install the filler panels as well? Any part numbers on the brackets?
" You are only coming threw in waves,... Your lips move, but i can't hear what your saying" |
