wiring one wire alt
how do i wire amp guage with one wire 12 volt alt on 53gmc
Re: wiring one wire alt
I'd recommend switching to a voltmeter. Ammeter can be a possible hazard, especially with a newer 12 volt system. Mad Enterprises has a lot of good info on their web site about alternators, gauges, and such that is very practical. Might want to take a look. Oh, yeah - I'm not affiliated with them, I just like the technical info they have.
I'm not sure you can add an amp meter to a one wire alt. Don't quote me on that just yet and let me double check, but I think that's one of the downfalls to the one wire alts....
1960 C-10 2000 Dakota R/T 1966 Fury I 2dr post 1984 Big Bronco 2002 Durango SLT (Bride's Ride) |
#4 | |
that connect through relays when the winch is activeted. |
your 53 amp gauge is 30 amp, a typical 1 wire alternator is 100 amp.
i would hook a 10 ga wire from the post on the alternator directly to the battery by-pass all the under dash wiring and a possible wiring fire i converted the amp gauge on my 58 to a volt gauge, look in my truk build for info if your the adventurous type, try converting your stock amp ga to a volt gauge ![]()
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
Try here under electrical tech you should find an answer, I have done it but don't remember all the details.
http://www.madelectrical.com/index.shtml
http://67-72chevytrucks.com/vboard/s...d.php?t=413926 http://youtu.be/Qe9xJUhWkWc |
I have a one-wire hooked up to my '59 and I still use the stock amp meter. What I was told to do ( from So-Cal Speed Shop ) is take a 10ga wire and jumper between the two posts on the back of the gauge. The reason for this is to tame the current accross the gauge and make it less sensitive. I still see the needle move to the right upon startup and then it settles down after running for a while.
#8 | |
Before I installed the 10ga jumper the needle would jack all the way to the right of the gauge. I was told as long as you see trending from startup to normal operation you were fine.
#10 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=505185 It is true that the jumper would cause the amp guage to read lower than it would without it. That was the purpose of putting the jumper on my guage, so it wouldn't peg when the alternator was charging at a high rate. The original amp guage is only marked "C" and "D", not a specific number of amps so it would not be correct to call it inaccurate. It's just an indicator that the charging system is (or isn't) functioning as it should. I wanted to keep my gauges looking and acting completely original and that's why I did it like I did. I never saw this suggested anywhere else. I wonder when So-Cal started giving out this tip. |
I don't know. I went there and asked if they had a aftermarket voltage gauge that would adapt to a 55-59 instrument cluster. He said no one made anything like that, that's when he gave me that 10ga jumper trick.
#12 | |
Thanks 4 all the info. Found out from auto rewire it would be fine to wire guage in series from alt. 2 bat. Using a fusible link my alt. Is 63 amp and guage is 50 amp
