07-02-2012, 09:23 PM | #1 |
Bazzar's 86 c10 5/7 drop..
I finally got the time and resources to drop my truck.The first phase was to get my exhaust and c notch done, Then began the install of the rear end first,I went with the DJM 1024 flipkit and 2" drop shackles,Install is pretty strait forward keep in mind that is just a basic kit, Does not include spring plates and u bolts.The main problem was drilling the 1/2 inch hole in the factory spring plates,this was a educated guess at best , but turned out fine after we basically installed it then pulled it back out to fine tune it..also the stock plate does sit way to close to the drop shock adapter ,anyone else have that prob. ? The next problem we encountered was the drop shackle wouldn't clear the bed frame rail. There is not alot of info on it, So yes it must be cut to clear shackle. Other then a few minor setbacks it went well, with all that being said it probably best to just spend the money , $50 or less for the spring plates, The back being done we went upfront and installed my 3" drop spindles and cut one coil off the front spring which is approx 2" for total of 5" overall. The front went smooth until we realized the brake line were pinched right between caliper and spindle, a little tweak of the hard line fixed that,and yes i was very careful not bend it.The total drop took all day..a long one at that...So thanks for looking and I'll keep ya updated on my next project, rollpan and some tint..
Common sense is not that common... Last edited by Bazzar c10; 07-02-2012 at 09:39 PM. |
07-02-2012, 09:30 PM | #2 |
Re: Bazzar's 86 c10 5/7 Drop
Here are some pic's of my truck...before and after..
Common sense is not that common... |
07-02-2012, 09:43 PM | #3 |
Re: Bazzar's 86 c10 5/7 drop..
Looks good sounds good. Heres the pic I got. Turns plenty of heads which is always a good feeling.
1979 SWB 350/350 |
07-03-2012, 11:41 AM | #4 |
man, that is one sweet ride! nice job with the slam....it sits absolutely perfect. the only thing i would change on the whole truck would be swap to a sport rear bumper....its got a really good classic but custom look. just awesome! what kind of bolt-in c notch is that? djm?
my 86 c10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=496829 my 56 3100 build: http://67-72chevytrucks.com/vboard/s...09#post5712509 my 95 silverado build: http://67-72chevytrucks.com/vboard/s...35#post5879335 my gray 86 c10 http://67-72chevytrucks.com/vboard/s...34#post7624734 |
07-03-2012, 09:07 PM | #5 | |
07-06-2012, 03:16 PM | #6 | |
07-03-2012, 12:25 PM | #7 |
Nice job man. Sits perfect.
07-03-2012, 08:20 PM | #8 |
Hey buzzar what size tires and wheels are you running?
1980 1/2 ton shortbed project 1978 grand prix project Never stop trying... |
07-04-2012, 07:22 PM | #9 |
Nice name play rusty4x4...lol,The tires were on it when i acquired the truck they are 235-75-15 on stock truck rallys. They actually ride some what nice and still have lots of tread left so ill just run em for now...I dont think they look that bad for now... Whats your set up dusty ? it looks real nice, looks like you did a real nice job on your truck, nice ride..
07-03-2012, 08:46 PM | #10 |
Home Built '87
Nice!!!
Gordon 1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424 1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833 Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969 |
07-05-2012, 05:36 AM | #11 |
I love it!
07-05-2012, 08:33 PM | #12 |
Thanks squaredaway,Ya your truck was what inspired me to go with the 5/7 drop, ..your truck has had many looks over the years all of them very tasteful. The setup your running now it definitely my fav.How do you like that 700r4 trans ? bet that's super nice, anyway thanks again for looking..
07-06-2012, 11:27 PM | #13 | |
07-11-2012, 01:45 PM | #14 |
The drop is awesome. I too just did a 5/7 last weekend and am still doing the finishing touches. I am replying to your comment about the shock extensions and spring plates. Yes, they are very close. At first I didn't think it was going to work! But there is no problem with them being close. Also, my bed does not have the large supports underneath where you had to cut for the shakle, and I did not have to cut the support. I have all the way to the bottom of the bed (so I have about an inch of room there now). Could be because mine is a '75. Anyways, nice lookin ride.
lowfastnloud |
07-12-2012, 10:43 PM | #15 |
Nice step LOW7FO. Good to see some more locals on here. Bazzars truck is killin me cause I have to see it all the time and mines not down yet but.... ordered my tens today for the back and next will be flip and shackles woohoo.
1979 SWB 350/350 |
07-12-2012, 11:39 PM | #16 |
looks good man , it does sit perfect
08-25-2012, 02:45 AM | #17 |
Looks good.
BTW, my parents live in Vancouver. |
08-25-2012, 04:00 AM | #18 |
Quick question, Did you use drop shock with the shock extenders or stock? I'm new & tryin to learn, Thanks
08-27-2012, 11:10 PM | #19 |
I used djm shock extenders that came with the djm 1024 kit and i used stock shocks on rear and stock shocks up front.It seems to ride really nice
