07-03-2012, 02:38 PM | #1 |
1963 230 engine
Does anyone have pictures of a 1963 trucks all original under the hood?
I need to see how the choke hooks to the carb and where it comes through the fire wall. If I could see if with the breather off it would be best. I have had my truck apart so long I have forgot and I want it to be correct. |
07-03-2012, 03:22 PM | #2 |
Re: 1963 230 engine
There is a small bracket off the carb that holds the choke cable. I can get pics tonight for you.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
07-03-2012, 03:38 PM | #3 |
Re: 1963 230 engine
See if this helps...Ist pic....to the left of the plug there are two lines. The line closest to the plug is a braided vacuum line, the choke cable is to the left of the vacuum line. 2nd pic shows the cable support bracket
07-03-2012, 11:16 PM | #4 |
Re: 1963 230 engine
Thanks that is what I needed.
07-04-2012, 07:29 AM | #5 |
Check The Champ, Demonstrator
Re: 1963 230 engine
Goes through the rubber grommet on the cowl beside the master cylinder in the hollow of the transmission tunnel. Depending on what other options the truck has, the number of holes in this grommet will vary.
