Old 07-05-2012, 01:59 PM   #1
gboom52
Question 52 5 window
i have a 97 s 10 ext cab pickup i was doing the frame swap to my 52 .and i was wondering because of the ext cab would i have to cut frame down some and if so how much and where. thanks
gboom52 is offline   Reply With Quote
Old 07-05-2012, 06:43 PM   #2
mr48chev
mr48chev's Avatar
Re: 52 5 window
Yes. What's wrong with the stock frame?
Old 07-06-2012, 06:30 AM   #3
coralhead
coralhead's Avatar
Re: 52 5 window
I know where this is going and I agree........
coralhead is offline   Reply With Quote
Old 07-06-2012, 07:05 AM   #4
gboom52
Re: 52 5 window
Nothings wrong.I just wanted to swap because it's cheaper than the mustang 2 swap.how much do I have to cut and where.
Old 07-06-2012, 11:30 AM   #5
robin58
Re: 52 5 window
I always thought it was the older body style 83-88 S10 single cab long box that was the desired one to swap? And preferably a 4x4.
But... your best bet is to go grab the dimensions of the existing chassis from the Shop Manual and then lay everything out on your new frame.
Or there's a wealth of info here: http://www.jalopyjournal.com/forum/s...light=s10+swap
robin58 is offline   Reply With Quote
Old 07-06-2012, 11:35 AM   #6
D-man313
D-man313's Avatar
Re: 52 5 window
Preferably use a regular cab long bed s10. Ive seen people use the extended cab frame, but not sure how much was cut.
I used a 98 regular cab long bed frame. Feel free to PM with any questions
Mom, I think I may have broke something. My tires keep spinning and leaving black marks every where
D-man313 is offline   Reply With Quote
Old 07-06-2012, 12:06 PM   #7
geoffcalii
Re: 52 5 window
i just cut down an ext cab frame, took out 5inches reight behind the factory joint up front.
geoffcalii is offline   Reply With Quote
Old 07-06-2012, 12:35 PM   #8
S10Fan
Old Heap Driver
Re: 52 5 window
Long bed standard cab frame is the best and most used chassis. I used a short wheel base frame for my 50, had to add a few inches in the middle to make it work.
My stock frame was hacked to death and not safe for anything but the scrap yard. If, my stock frame had been in better shape I would have used it along with some sort of aftermarket front end. Much easier to work with a stock frame than trying to fit everything to an S-10 frame.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 07-06-2012, 01:16 PM   #9
n_elsod
n_elsod's Avatar
Re: 52 5 window
I used an 88 extended cab short box 4x4 for mine and didn't have to cut the center. I did have to take some off the front and back though. The wheel base is 1" longer than a 51 and the axles are 1" narrow than a 51.
n_elsod is offline   Reply With Quote
