Old 07-05-2012, 05:01 PM   #1
HotRodScottsdale
HotRodScottsdale's Avatar
Pumps going, good time to replace column?
My power steering pump is leaking pretty bad so it's time for a new one, my question is would this be a good time to get a new steering column with tilt?
On a quite night you can hear a ford rust
HotRodScottsdale is offline   Reply With Quote
Old 07-05-2012, 10:57 PM   #2
1774btcrew
1774btcrew's Avatar
Re: Pumps going, good time to replace column?
Is your steering box leaking or the pump? If it is just the pump it wont matter when you do it.
1774btcrew is offline   Reply With Quote
Old 07-06-2012, 12:51 AM   #3
HotRodScottsdale
It's the pump, it's leaking being the pulley wheel. I was just curious if replacing the column would require draining all the fluid and all that and figured if I gotta do it already might as well do it all at once
Old 07-06-2012, 01:15 AM   #4
kwin
kwin's Avatar
The steering pump and power steering box have little to do with column, there is just s mechanical connection between the column and box. There is no reason to drain the fluid when changing the column.This is no better or worse time than any other to change the column.
Kwin
kwin is offline   Reply With Quote
Old 07-06-2012, 01:18 AM   #5
HotRodScottsdale
Any body got pics of a column off and how it all works?
Old 07-06-2012, 07:10 AM   #6
motornut
78K & 79C Jimmys
motornut's Avatar
to fix the pump you don't need to remove it
this coupler joins it only to the steering box
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 07-06-2012, 08:52 AM   #7
Telecasterjoey
Hey motor nut where did u get that rag joint? Expensive?
Telecasterjoey is offline   Reply With Quote
Old 07-06-2012, 02:47 PM   #8
motornut
78K & 79C Jimmys
motornut's Avatar
I'm not sure but I think it was under 50
I just put it on my account and they send it over
John
Old 07-06-2012, 02:46 PM   #9
HotRodScottsdale
Sweet thanks, I will just fix the pump then till I can find a nice column
