07-08-2012, 09:05 PM | #1 |
Looking for cheap, broken, cracked, chipped a/c vent ball housings
This might sound a little weird, but I'm looking for a rt & lt vent ball housing to use as a template. I want a set that's basically not good enough to use. Thanks!
1967 Chevy C-10, 250 L6, Powerglide, 3.73, SWB, Fleetside Upgrades: Power steering, Offset air cleaner, Rear Sport bumper, 3 point safety belts, HEI, -1/-2 springs, 16x5 wheels, McGaughy's disc brake conversion, Sway bar |
07-09-2012, 02:18 AM | #2 |
VA72C10
Re: Looking for cheap, broken, cracked, chipped a/c vent ball housings
ttt for you. I might have a broken useable set for a template but likely will be a while before I can get to the box to look for them so hopefully someone else has a set....or has a template for you...I remember seeing one on the board in the FAQ section likely?
Looking for a 67-72 swb or blazer project in or around VA. |
07-09-2012, 10:51 AM | #3 |
Thanks! I have templates, but I want the most assurance possible before I do any cutting. I'm essentially going to cut the connector off of the back of the housing so it will sit flush against the dash.
07-09-2012, 11:07 AM | #4 |
if the template ends up being correct after all is said and done, please let me know where you got it..
