07-09-2012, 10:10 PM | #1 |
Brake Master cylinder question
When I purchased this latest truck, I was going to put disc brakes on but, decided to leave it drums( with power ) all way around for now. Question is: Will the mastercylinder/booster with proportion valve still work?
Thanks, Bill |
07-10-2012, 12:53 AM | #2 |
60-66 Nut
Re: Brake Master cylinder question
If you are talking about using a disc/drum master cylinder with a drum/drum system, I can't say for sure how it will work. Why not just switch the master cylinder to a drum/drum unit and eliminate the proportioning valve. That way you know it will work. Rebuilt or new master cylinders aren't that expensive.
07-13-2012, 06:45 PM | #3 |
Thank you for the info Captainfab.
07-13-2012, 09:21 PM | #4 |
a reman master for a 67 impala drum/drum will do the trick, $23 from advance auto parts, and others I am sure
Craigerrr My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709 |
