Old 07-12-2012, 10:03 PM   #1
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
at whits end
im at whits end with this starter installed it no shims like my last starter worked awsome 4 days later starter has slight grind :S so i get a shim kit install 2 shims as per my old boss (great mechanic) tryed starting it started with a slight grind. turned it off started it again huge grind. > so i try three shims starts awsome tred a few more times starts awsome then last try GRIND! what am i doing wrong?
If it aint square, I don't care.
84 C35 CC Dually Project log...
http://67-72chevytrucks.com/vboard/s...d.php?t=414892
1tonchevy is offline   Reply With Quote
Old 07-12-2012, 10:52 PM   #2
Krwright
Re: at whits end
I fought this same thing on a blazer. Went through countless shims and starters. I read in a book that with the starter engaged you should be able to bend a paper clip wire and have it fit snug between the teeth of the starter and flywheel. I tried it with no luck. I changed the flywheel and haven't had a problem since.
i do my burn outs in 4wd
Krwright is offline   Reply With Quote
Old 07-12-2012, 11:04 PM   #3
cjlinkster
cjlinkster's Avatar
Re: at whits end
I would check that flywheel....
The only time that I have every had a new or rebuilt starter start grinding that soon; the flywheel had issues.
1984 C20, 454, 4 speed named "Gold Member"
cjlinkster is offline   Reply With Quote
Old 07-12-2012, 11:25 PM   #4
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
Re: at whits end
what do i look for? because i have looked at the teeth and they appear to be fine. do they just go?
Old 07-12-2012, 11:39 PM   #5
chebyshortbox65
chebyshortbox65's Avatar
Re: at whits end
Do you have the front support from the starter to the block on there?
chebyshortbox65 is offline   Reply With Quote
Old 07-12-2012, 11:46 PM   #6
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
Re: at whits end
my truck never had that
Old 07-13-2012, 06:58 AM   #7
chebyshortbox65
Re: at whits end
Someone left it off at one point you would ne surprised at how much it helps and keeps the starter from flexing
Old 07-13-2012, 07:16 AM   #8
rs72z
rs72z's Avatar
Re: at whits end
You might need to shim only the outside bolt. That will tilt the starter in and get the teeth closer to the flywheel.
___________________
78 ccsb dually
5.3
4l60e
http://67-72chevytrucks.com/vboard/s...d.php?t=491551
rs72z is offline   Reply With Quote
Old 07-15-2012, 01:25 PM   #9
C-10 simplex
Re: at whits end
Exactly---and if you have someone crank the motor while you watch you'll see how much it moves!
C-10 simplex is offline   Reply With Quote
Old 07-13-2012, 04:54 PM   #10
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
Re: at whits end
bought and installed a high tourqe start no issues so far.
