Old 07-14-2012, 11:12 AM   #1
82ccshorty
82ccshorty's Avatar
4x4 conversions
I have seen that people do 4x4 conversions on this site. Well i have a 76 c30 that i would like to turn into a 4x4. My question is, is it cheaper to do a 4x4 conversion or buy a k30? i know where there is a k30 but neither one of the axles are there pretty much no drivetrain at all. no motor no trans no transfer case and no axles. so what would be cheaper for me? and how hard is a 4x4 conversion?
1969 chevy camaro Z28 #matchin Factory 4wheel disc
1969 chevy cst10 big block overdrive 5/7 drop dog dishs
1997 gmc yukon 2 door 2 wheel drive project 4/5.5 22s
2004 gmc sierra dually 4/4 lowering daily driver
82ccshorty is offline   Reply With Quote
Old 07-14-2012, 11:31 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: 4x4 conversions
It really depends on whats common in your area. In some regions where the K trucks are used a lot for snow plows, finding a good K30 might not be cheap. In other areas where they 4wd isn't used much, they are just gas hogs and can be had at a reasonable price. Check Craigslist and see what your region has to offer.
If you can find a complete K30 and its what you want at a fair price then that would be the simplest route to take. If not, then a K30 parts truck would be a good choice. When doing a conversion its best to have a complete donor so the small parts don't nickel and dime you to death.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 07-14-2012, 11:36 AM   #3
82ccshorty
82ccshorty's Avatar
Re: 4x4 conversions
I could take the c30 and the k30 and make one right?
Old 07-14-2012, 11:48 AM   #4
v30crewcab
v30crewcab's Avatar
Re: 4x4 conversions
its alot easier to just use the k30 frame than the the c30. its alot of work changing the rivets everywhere to swap the spring hangers out.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 07-14-2012, 12:24 PM   #5
spencer_41188
spencer_41188's Avatar
Re: 4x4 conversions
im getting ready to make my 87 r30 a 4x4 im using a 80 gmc k35 for a parts truck seeing it had a dana 60 and a np205 behind a 400 trans but im doing one better putting a nv4500 in the truck too so hello hiway all the spring hangers and shackles im getting from diy4x.com im thinking about keeping the overloads but changing the main springs to a 1/2 ton truck for a softer ride
88 gmc v3500 bonus cab classy chassy conversion, 454, nv4500, np205, dana 60 front with spool, 14 bolt ff cac rear with locker.
spencer_41188 is offline   Reply With Quote
Old 07-14-2012, 08:10 PM   #6
82ccshorty
82ccshorty's Avatar
Re: 4x4 conversions
I think I'm going to buy the k30 and use everything enterchangable from the c30 on it
Old 07-15-2012, 06:15 AM   #7
spencer_41188
Re: 4x4 conversions
from 73 to 80 all the parts will cross over and you will need to drill a cuple holes for the core support/spring hanger and cut a hole for the shackle eye. you may have to drill some holes for the crossmembers dont worry if the parts truck is a srw as long as it has a dana 60 because dually hubs are easy to come by i got a set from www.extremeaxlesales.com and they where $100.00
the parts im getting from diy4x.com are the b52's, frame eye and templet to cut it out with a plasma, the 64 rear spring hanger and the shackle flip kit for 1ton. im doing this so i can get the 4inch lift i wont but also i will get a softer ride and more wheel travle for off road and i wont the wheels center in the wheel wells
Old 07-15-2012, 07:58 PM   #8
82ccshorty
82ccshorty's Avatar
Re: 4x4 conversions
How hard is it to find a Dana 60
Old 07-15-2012, 08:38 PM   #9
Mattman2010
Mattman2010's Avatar
Re: 4x4 conversions
I have done the 4x4 conversion on my crew cab that I have. I just used parts off of a k20 that I had for the front and found some rear spring hangers off of a k30 that someone cut them off of. As for finding a dana 60 that depends on your area. You will just have to keep checking craigslist and see if there are any for sale. A parts truck or a k30 truck would be the best way to go that way you can either swap the body over to the k30 frame or cut the parts off of a parts truck to do the swap.
1980 K10 - 6.2L Diesel/SM465/NP205
Build Thread
1984 K30 CC Dually - "The Tank"
12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's
Build Thread
1960 C-60 Dump Truck
Make it road worthy!
Thread
Mattman2010 is offline   Reply With Quote
Old 07-15-2012, 08:51 PM   #10
82ccshorty
82ccshorty's Avatar
Re: 4x4 conversions
well i know where there is a k30 crew cab dually but it has no axles under it and no engine or trans. its pretty much just a frame and body. i am considering buying it and fixing it. So i will need to find a dana 60. the guy is suppose to throw in the 14 bolt rear if i buy it.
Old 07-15-2012, 10:13 PM   #11
Mattman2010
Re: 4x4 conversions
Well then I guess it depends on how much the guy is asking for it. Is the truck in really good shape? I would say that a Dana 60 would be around $1000, but some times you can get lucky and find them for around $600.
Build Thread
Build Thread
Thread
Old 07-15-2012, 10:31 PM   #12
82ccshorty
82ccshorty's Avatar
Re: 4x4 conversions
He wants a 1300$ and it's not negotiatable.
Old 07-15-2012, 10:39 PM   #13
Mr. 250r
Mr. 250r's Avatar
Re: 4x4 conversions
how hard is it to find a d60? lol the question is how hard is it to find a reasonably priced one because everyone thinks that axle is like the winning lottery ticket, i would only be interested if its 950 or cheaper i got an 86 d60 and matching rear axle for 850 complete so the deals are out there just gotta wait them out
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold
2003 1500 Silverado
2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LWB
Mr. 250r is offline   Reply With Quote
Old 07-15-2012, 10:54 PM   #14
82ccshorty
82ccshorty's Avatar
Re: 4x4 conversions
I found one out of a 1 ton dodge that was 800$ but what's the difference between it and a Chevy?
Old 07-15-2012, 10:46 PM   #15
Mattman2010
Re: 4x4 conversions
I hope that thing is in good shape. $1300 seems a lot to me for a non roller with no motor trans or transfer case.
Build Thread
Build Thread
Thread
Old 07-15-2012, 10:53 PM   #16
82ccshorty
82ccshorty's Avatar
Re: 4x4 conversions
He said t was I don't know because I haven't looked at the truck yet. He said he thought it was a real solid truck
Old 07-16-2012, 03:10 PM   #17
spencer_41188
Re: 4x4 conversions
http://www.pirate4x4.com/tech/billavista/60_front/ ... this will tell you all the diffreces on the chevy, dodge, and ford dana 60s and yea you can find a dana 60 but people think its gold and when you compair the price of a fully loaded brand spakin new one from curry or crane you will wonder wtf my best advice is to find a compleat truck and part it out and like i said befor it dont have to be a dually dont limit your options
i know a fue people that truck pull and they use a 10bolt or a dana 44 up front and they havent had a problem with axles breaking
and about that truck he said he would throw in a 14bolt! you wont find a 14bolt under a full width dually there all dana70 now a cab and chassis like mine has a 14bolt but it has dually hubs and the brakes are moved over to alow dually hubs
i seen an episode of xtream 4x4 where they made a front axle out of a 14bolt using crane hi clearence parts ... just an idea
Old 07-16-2012, 06:12 PM   #18
82ccshorty
82ccshorty's Avatar
Re: 4x4 conversions
Could I use a Dana 44 and keep it a dually? I'm not going to be towing with it or anything but I like 4x4 duallys
Old 07-16-2012, 07:48 PM   #19
spencer_41188
Re: 4x4 conversions
yes you could use a dana 44 idk if the dually hub will fit but you can put a 2.5" or a 3" spacer, 6 to 8 lug adapter or 5 to 8 lug adapter inless you wana roll around with mix mached rims
i think the cheapest axle would be the 10bolt because them off road jeep guys love the dana and they will fab up some crazy stuff to make it work
heres a good place to get some ideas on where to find an axle http://www.pirate4x4.com/tech/bible/index.html
Old 07-16-2012, 08:52 PM   #20
82ccshorty
82ccshorty's Avatar
Re: 4x4 conversions
I think I'm going to buy it and find a Dana 60. My buddy usually has a few
Old 07-17-2012, 09:51 AM   #21
82ccshorty
82ccshorty's Avatar
Re: 4x4 conversions
what transfer case would a 1980 crew cab with a th400 use? a 205 or 208?
Old 07-17-2012, 11:20 AM   #22
Mattman2010
Re: 4x4 conversions
I would say that it has a 205.
Build Thread
Build Thread
Thread
Old 07-17-2012, 11:47 AM   #23
82ccshorty
82ccshorty's Avatar
Re: 4x4 conversions
thats what i thought but i was unsure
Old 07-17-2012, 02:50 PM   #24
82ccshorty
82ccshorty's Avatar
Re: 4x4 conversions
Does anyone have the blues that would be on a 80 model? its a blue and white but idk what color would be on a 80
