Old 07-15-2012, 11:51 AM   #1
blackdawg
Blackdawg
automatic transmission not engaging
I had my turbo 400 rebuilt a while back.finally got everything in.the problem i"m having is the transmission is not engaging.I had a transmission leak from the line that was dropping a bunch of fluid.I have tightened that up as well as the pan bolts.the vacuam line is running from the modulater to a port on my edelbrock carb.the sensor which i guess would be for transmission pressure is not hooked up.I topped the tranny up last week and left it after chasing leaks.so this morning i will start the truck and make sure the level is up.what else can i check for if this thing doesn"t move getting very frusterated.truck is a 1966 chevy stepside with a 350 and turbo 400 with b&m shift kit.thanks
LIFE NEEDS NO RED LIGHTS !!
1966 chevy stepside. Aka Bella.
1998 chevy s-10 4x4 daily driver.
my build thread http://67-72chevytrucks.com/vboard/s...d.php?t=467164
blackdawg is offline   Reply With Quote
Old 07-15-2012, 07:40 PM   #2
fleetman
Re: automatic transmission not engaging
get one of those turbo 400 transmission books. they are invaluable. they have a great diagnostic/troubleshoot section. try barnes and noble or amazon if you want to get it.
but you are on the right track to hunt down your problem. it will always slip if you are seriously a leaker. also any vacuum leak to the trans will cause it to slip or not work. neutral switchs can problem sometimes. i assume you checked that linkage is working proper. closely inspect for any obvious problems.
hth
fleetman is offline   Reply With Quote
Old 07-15-2012, 07:43 PM   #3
blackdawg
Blackdawg
actually i was able to move it this afternoon.runs very rough right now.Going to have a buddy of mine set her up a bit.But drove her it was very exciting drove like a bucket of bolt but it nice to see her move.
