Old 07-15-2012, 07:57 PM   #1
chris mc bride
chris mc bride's Avatar
Panels wooden floor replacement
Can the plywood rear floor be replace with oak flooring like in pickups. Im wantint to replace mine althought it has no rotten ares. Amazing the lowers have been gone but the plywood is still solid as can be..
I would like to use oak or if could find Brazillian Cherry and have the hold down strips chromed,guessing they are not same as PU. I found a piece of brazialian Cherry cpl years ago and last year got bored and made this stock out of half of it and its freaking gorgeous wood.
chris mc bride is offline   Reply With Quote
Old 07-15-2012, 08:16 PM   #2
vectorit
What?
vectorit's Avatar
Re: Panels wooden floor replacement
Pretty sure one could do what you want, but I would use a 3/8 ply for the bottom as the base.
If you made a rifle stock (beauty of a stock by the way), I am sure you could do all the work to make it right.
Is this for a burb or a panel?
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 07-15-2012, 09:53 PM   #3
chris mc bride
sorry proof reading would have helped/ Surpose to read Panel's wooden floor. Its 69 panel thats me avatar.Lots body work to fix first,but figure no suck thing as researching to much or to early.
Old 07-16-2012, 01:43 AM   #4
olharleyman
I would bet you could at the very least use to plywood floor as a base for putting down a lament floor like in a house if not pergo so it can contract and expand with the weather. I am thinking about doing it on my 69 3 door and see what happens sounds like a good idea anyway but we'll see.
1969 1/2 Ton 3 Door Suburban
Clam Shell Rear
454 Turbo 400 With Shift Kit
Air Bagged On 20" Wheels
olharleyman is offline   Reply With Quote
Old 07-16-2012, 01:45 PM   #5
OneOffStroker
From the looks of the picture with that rifle, you have wood floors already. Maybe not in your panel, but somewhere. Like Olharleyman said, and like I'm gonna do...lay down some Laminate. Home Depot or Lowes have about 100 different types and textures to choose from. I'm sure you can find a match for what you're looking for. I know it's not real, but it can look good. One member on here did it and he said it 'squeaks' but maybe with some extra laminate underfoam it might not be bad. I got some faux Brazilian 2-tone wood laminate from Ikea that I'm going to put in my Burb. I'm going to use extra foam under it and put a few dabs of clear silicone in the joints to help dampen any squeaks that may form.
1972 C10 "Shop Truck" Build - EFI, 5-speed, Posi, and Patina http://67-72chevytrucks.com/vboard/s...d.php?t=834292
1957 Chevy pickup - Twin Turbo 5.3/NV3500, Jag IFS & IRS, AirRide http://67-72chevytrucks.com/vboard/s...d.php?t=606987
Check me out on YouTube - "Tiny Garage Fabrication" http://www.youtube.com/oneoffstroker
OneOffStroker is offline   Reply With Quote
Old 07-16-2012, 06:08 PM   #6
chris mc bride
Ok look at the wood instock . Im true lover of hardwoods oak,walnut,cherrys and such.I put hardwoods in some homes mine has those damn lamanets and not going in my panel. Yea lot cheaper but this is not going to be cheap project when done.Lots of custom desing work already in makings. I might have to step down to oak from the brazailan cherry I want. But that about as far as I entend to go.
I wondering if it can be installed sameway as truck.If need a bottom like plywood why can't I just use metal maybe reverse ribbed (for strength)aluminum that could be painted under side.
Old 07-18-2012, 06:04 PM   #7
6772king
6772king's Avatar
yeah u could,,, the crossmembers are the same setup,,,i would just drill some more holes 2 put more strips in ,,,
67 chevy short step 2wd 427
71 chevy short fleet 4x4 396
72 gmc jimmy 2wd 377
71 chevy blazer 4x4 454
69 chevy longhorn 5.9l cummins
72 chevy 400 2wd custom camper
67 chevy lwb 4x4 454-in pieces
67 chevy panel soon 4x4-400
67 gmc dump 4x4 1 ton-305 WTF!!
72 chevy 3/4 ton 4x4 burb 350
70 chevy panel 2wd 302 5 speed tko
"THERE IS NO REPLACMENT FOR DISPLACMENT"!!!!!!!
6772king is offline   Reply With Quote
Old 07-20-2012, 08:19 PM   #8
chris mc bride
how about strips looks like only choice is use originals. Panels have longe floor than truck does. So Im guessing getting these chromed only choice fpr chrome one unless someone know where i might find them.
Old 07-20-2012, 08:21 PM   #9
chris mc bride
no not wood floors laminate when built house was surpose to sell but then osama took office and the fall out from clinton policy of everyone gets house loan reguardless had already happened. Ended up moving into house in order to try to save company and my butt. If built it for my self it would have had hardwoods.
Old 07-21-2012, 01:22 PM   #10
6772king
6772king's Avatar
i just went out and measured my longhorn and panel floor and the longhorn is only a 1" shorter than the panels floor,,, that is inside of angle to inside of angle,, u use to be able to get them without holes,,,i dont know if u still could or not though,,
Old 07-23-2012, 03:07 PM   #11
chris mc bride
Thanks 6772KIING
