Old 07-17-2012, 06:14 AM   #1
kgmunro
Long to short question
When you cut a long box down to a short box, what do tou do with the trailing arms? Just cut them in the middle somewhere and plate them??
kgmunro is offline   Reply With Quote
Old 07-17-2012, 06:23 AM   #2
markeb01
Senior Enthusiast
markeb01's Avatar
Re: Long to short question
The trailing arms remain unchanged. The section of frame that is removed is ahead of trailing arm crossmember, so nothing in the suspension is modified.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 07-17-2012, 06:59 AM   #3
lucifer
lucifer's Avatar
Cool Re: Long to short question
I found a flat section of frame ahead of the trailing arms and cut out the 12 inches required. Nice square cut and boxed the inside of the frame. The only other part I needed to move was the rear cab mount back 12 inches . Then 8 inches off the rear of the frame.
regards
65 burb On the road Mar 26th Finally
lucifer is offline   Reply With Quote
Old 07-17-2012, 07:47 AM   #4
kgmunro
Thanks guys, I should look before I ask questions ...
Old 07-18-2012, 04:06 PM   #5
oldsnakebite
oldsnakebite's Avatar
Like the guys before said, trailing arms and cross member stay the same. Just removed the 12 inches in the center and 8 off the back. Then move the cross member forward 12 inches. I did mine years ago, cutting the frame just behind the cab. I have hundreds of pics of the job if you need them.
I have not failed. I’ve just found 10,000 ways that won’t work.
oldsnakebite is offline   Reply With Quote
Old 07-18-2012, 05:17 PM   #6
markeb01
Senior Enthusiast
markeb01's Avatar
I forgot to share this thread which explains the project nicely:
http://67-72chevytrucks.com/vboard/s...d.php?t=123624
