Engine installions
I'm going to be installing my bbc soon. How many of you guys have used the carb flange lift plates? It just seems like its alot of weight for the threads in an aluninum intake. I'm running iron heads too. I wasn't worried about my iron headed sbc but, this one weighs alot more.
1987 R10 Pump Gas 496/TH375 Best 1/4 pass to date 60' 1.49 1/4 10.93 MPH 120 |
It's Better With Nitro
Re: Engine installions
I don't use the carb lift plates for the reasons you noted. I've had an engine sling similar to this one from PitPal for many years.
http://www.summitracing.com/parts/PIT-201/
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
I do have an engine tilter that i may use. I also may use the old chain method too.
Registered Truck Offender
The engineers will gladly tell you how each 5/16-24 bolt will hold the weight of the engine if it is inserted at least .375" into the threads of an aluminum intake manifold carb flange and torqued to spec,, but HELL NOOOo I ain't standing under a fully dressed pigblock even if it had a safety chain.
I made a harness from the long tails cut off of of those 20' tie-down's and old seatbelt hardware. Works like a champ,,, bigblock or small.
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
