05-20-2003, 11:33 PM | #1 |
hoods that dont sit flush at cowl
My 68 hood does not lay flush back at the cowl, you know the look....after closing it you have to walk back and push down on the hood and it stays down.
are the springs wornout? is it the hinge? or both? Thanks in advance |
05-20-2003, 11:50 PM | #2 |
Hot Damn - Here I Am!!
I believe this is caused by worn out hood hinges but if it's not too bad it might be adjusted out at the rear adjustment bolt on the hinges.
Robert
My vehicles: '90 Silverado Sport '71 Chevelle SS Convertible '70 C-10 - My Grandfather bought it new - original un-restored |
05-21-2003, 12:22 AM | #3 |
Usually it is the rivets on the hinges that are starting to fail.
Just sitting here contemplating contemplation. |
05-21-2003, 12:39 AM | #4 |
Here is some information posted a while back by a boardmember
named that goes by the name Huck. I tried it and it worked for me. Quote: Most people will say hinges/springs are worn out---duahhh---how come they weren't worn out before you replaced the motor?? In reality, even well worn hinges can be adjusted if you know the secret~~~and the secret is~~~~ 1- open hood and back off the three bolts that hold the hinge to the fender on each side. 2- have friend put a little additional upward pressure on the hood while you tighten the bolts. By putting the additional upward pressure on the hood, you reposition the hinges and put a slight bit of spring push on the hinge springs. When you bring the hood down, it should bottom out on the rear of the hood. Keep in mind that you may need to reposition the hood on it's hinge bolt position for proper left/right alignment. It is also important to have the hood alignment rubbers mounted in the fenders for the edges. Have fun
John Hutchison Grapevine,Texas 68 1/2 t swb 68 Mustang 69 Jaguar 71 1/2 t swb 88 Supra CompTs6m 93 Escort GT 2005 Corolla XRS |
05-21-2003, 02:51 AM | #5 |
Mine did that but I only needed to lubricate the hinges.
05-21-2003, 05:18 AM | #6 |
hinge
Hutch's method works unless maybe the rivets are ready to fall out. In that case, buy some good used hinges and use his method.
05-21-2003, 07:18 AM | #7 |
Heck go buy some new GM hinges !
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
05-21-2003, 08:34 AM | #8 |
1969 Custom 30 wrecker
The above method worked for mine too.
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
05-21-2003, 10:48 AM | #9 |
Holy Cra@ Batman, my secret is out and everyone is finding out that they don't need to spend mega bucks on new hinges. Now the hinge manufacturers are going to be coming after me.
Just an update to the process, if your hinges are truly well worn---like the rivets fall out----get hinges. If they were ok before you had the hood off------then adjust as described. You just need to loosen all 6 hinge mounting bolts where they go into the fenders then have someone push the hood up a wee b it further then it's fully open position which forces the hinge spings to flex a bit. Now tighten and you got it. If I had a $1. for ever truck I've seen with the hood up~~~~I could probably afford a decent bed floor for mine~. OK come on guys, everyone who has used this trick, post your reply so others will get the easy fix and save some $$$ for other more important stuff like HEIs, locking gas caps or even better , rear gas tanks so we don't have any members doing the Chevy truck barbecue!!! Now can someone repay the favor and help me find a good solid straight LWB floor???? HUCK |
05-21-2003, 12:17 PM | #10 |
67-72 Addict!
I remember this was a Christmas gift from Huck!. I tried it on my dad's truck and it didn't work. His hinges are probably shot. Since then he has picked up another set of hinges yet to be installed. It was still a nice gift Huck!.......Jim
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
05-21-2003, 12:24 PM | #11 |
Great question! Mine has the same problem. I can't wait to try this out.
Once again...this board ALWAYS has so much great info! Thanks! Now let's see if more people have tried this and their results.
Baby Blue's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=652776 Project 68's Build Thread: http://67-72chevytrucks.com/vboard/s...17#post8442117 www.stonecolumnclassics.com Email: Josh@stonecolumnclassics.com |
05-21-2003, 12:56 PM | #12 |
05-21-2003, 11:33 PM | #13 |
Thanks guys, my front clip is off and ready to put back together after body and paint......This long weekend will be fun.
