Old 07-24-2012, 03:12 PM   #1
Laser145
Sludge under valve covers...how do I clean that?
I'm working through the engine on my 87. Pulled off the valve covers and there is sludge everywhere!!! Black,oily, messy, sludge!
Whats the best way to clean this out? I'll use a spoon and screwdriver along with my 10 dirty fingers to get a lot of it... but eventually I'll want some solvent.
What is safe to use? I don't want to damage anything below when it runs down the galleys at each end of the block.
Cheers
Taylor
1987 R10
1976 K10
Laser145 is offline   Reply With Quote
Old 07-24-2012, 03:41 PM   #2
kelsfine69
18 Till I Die
kelsfine69's Avatar
Re: Sludge under valve covers...how do I clean that?
Spray a rag with brake clean or any cleaner like that. You dont want to be running the sludge down..if you get 90% of it then a few good oil changes should get the rest. Just a FYI...If you have that kinda sludge under the Valve Covers then the lifter gallery and the bottom of the oil pan will have some too. Its from a lack of oil Changes
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 07-24-2012, 03:45 PM   #3
Laser145
I figured it was from neglect... I'll remove the oil pan too...
Will I be able to get most of that out?
1987 R10
1976 K10
Old 07-24-2012, 09:43 PM   #4
kelsfine69
18 Till I Die
kelsfine69's Avatar
Yea with the pan off its easy to clean out...Still gonna take a couple oil changes.
2011 GMC Acadia
1969 GMC BBC LS7
42000Km
Old 07-25-2012, 12:13 AM   #5
bowtiemanchevyman
bowtiemanchevyman's Avatar
a easy way to clean all that out is to add a qt of ATF to your oil and run the truck for about a hour then drain the oil do that evry time your change the oil for a while untill it come out clean. The ATF cleans out all that slugand crap from your motor. trust me it work great.
bowtiemanchevyman is offline   Reply With Quote
Old 07-25-2012, 12:58 AM   #6
tinydb84
tinydb84's Avatar
I always did this with any used car/truck I bought for the first few changes
Old 07-25-2012, 01:19 AM   #7
broey
Square
broey's Avatar
type 2 diesel works good too. if you go to the store and buy sludge cleaner thats what its gonna be anyways.
Squarebody Syndicate
broey is offline   Reply With Quote
Old 07-25-2012, 02:23 AM   #8
KQQL IT
At the body shop.
KQQL IT's Avatar
Could also be a coolant leak. My brothers burb was serviced regulary ... the pan had so much sludge in the pan. Looked like jelly.
Old 07-25-2012, 06:57 AM   #9
xrcr
X2 on the #2 Diesel
xrcr is offline   Reply With Quote
Old 07-25-2012, 07:34 AM   #10
BigBlocksRule
I'm with the guys with the ATF, it works good.
If you have time and a couple of gaskets, pull the intake, too. You'll be surprised at the amount of sludge in the lifter valley. With the pan off, you can use naphtha, diesel, whatever you want to dissolve this crud and drain it through the lifter valley and out the bottom of the block. Same thing with the heads. While you have the pan off, use a flashlight to see if there's any that's accumulated in the bottom of the block - it's doubtful that there's anything there. Use cheap Brake Parts Cleaner to wash everything down. Button it back up, run the ATF for the first change (I wouldn't go more than about 500 miles on this change) and it should be good and clean.
If you do remove the pan and have a torque wrench, pull a main cap or two and the same with a couple of rod caps - do the back ones, they're the last to get oil. If they look worn but have no scratches, etc., you're probably fine - torque 'em back down and button it up.
BigBlocksRule is offline   Reply With Quote
Old 07-25-2012, 01:02 PM   #11
INSIDIOUS '86
INSIDIOUS '86's Avatar
Pull the caps farthest from the oil pump. They get oil last
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 07-25-2012, 02:48 PM   #12
BigBlocksRule
Last time I checked, the main oil galley runs from the oil filter to the front of the block inside that pan rail, then to the center of the block, then front to back. This is small, big and LS block except late generation big blocks and LS have priority main oiling. That's why the rear rods nearly always go first with contaminated or oil starvation problems.
Old 07-25-2012, 03:51 PM   #13
KQQL IT
At the body shop.
KQQL IT's Avatar
Old 07-25-2012, 04:04 PM   #14
Malo83
Cruzzzn' Vet
Malo83's Avatar
Does it look like this not mine just a pic I found on the net
Uploaded with ImageShack.us
Malo83 is offline   Reply With Quote
Old 07-25-2012, 08:04 PM   #15
Laser145
Looks like my truck!
1987 R10
1976 K10
Old 07-25-2012, 07:59 PM   #16
BigBlocksRule
Well, boy, I say, boy, give me that pointed hat, it's my turn to wear it for a while.
BIG blocks have the main oil galley running down the driver's side pan rail. Gen 5/6 relocated it to the cam tunnel and gave these blocks priority main oiling.
Old 07-25-2012, 08:06 PM   #17
shok
i had a motor that looked like that long ago. when i cracked a head the junkyard head looked 10 times cleaner, sad....
shok is offline   Reply With Quote
Old 07-26-2012, 09:20 AM   #18
Desert1957
Desert1957's Avatar
Be advised this engine if it looks as bad as the picture, is going to start having problems. noises or tapping.
I know you guys think you can flush this this stuff. I have seen a hammer and screwdriver needed. NO amount of oil changing can remove it. Any stuff you start scrapping a digging at will just start circulating causing more problems.
IMO drop the oil pan and replace the oil pump and pickup, this engine if sludge up will start restricting the oil pump inlet which can lead to no oil pressure and total engine failure.
Not that bad of a job , Oil pan can be removed in the truck. parts are reasonable, may extend the life a while longer.
Desert
Desert1957 is offline   Reply With Quote
Old 07-26-2012, 09:44 AM   #19
Laser145
That's the other question... Do I keep this motor or find a fresh one?
Around my shop we're debating what it's worth throwing at this motor when a replacement isn't terribly expensive. I've never swapped a motor before, but I'm willing to learn.
If this motor has been neglected for so long, how much time and money should I throw at it? Of course, it runs as is... So there's that, too...
Desert
1987 R10
1976 K10
Old 07-26-2012, 10:20 AM   #20
N2TRUX
Happy to be here
N2TRUX's Avatar
My Daddy used to tell me "Son, If it aint broke, don't fix it till it is.". If the motor is running good now, you might be better off resealing it and running it like it is. Yes, there are many ways to flush a motor, but there is a high probability that some of that grunge is going to stay inside unless you blow it apart.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 07-26-2012, 10:51 AM   #21
Laser145
Part of me feels the same way.
The truck smokes at startup a good bit, then it calms down but always smokes just a little... If I let it idle for awhile at my shop the smoke gets worse and worse...
I'm also chasing down a hesitation issue when you get down hard on the throttle...
So it's not perfect, but idles nice and moves to and fro.
1987 R10
1976 K10
Old 07-26-2012, 11:08 AM   #22
kelsfine69
18 Till I Die
kelsfine69's Avatar
Yea clean what you can, change oil a few good times and take it from there...If it gets worse then you have time to look for an engine, untill then drive her
2011 GMC Acadia
1969 GMC BBC LS7
42000Km
Old 07-26-2012, 12:36 PM   #23
shok
I agree that cleaning what you can might just get other gunk in the motor for the oil pump to pick up. I would just be good about oil changes and that's that, leave it alone. Dropping the pan and cleaning loose gunk there and changing the pick up is as far as i would go.
The hesitation is most likely just a tuning issue that could be fixed.
Old 07-28-2012, 05:19 PM   #24
Laser145
Today I changed the oil/filter and added 1 qt of ATF (also 1/2 pint of seafoam I had lying around. I'll drive it a bit then change it again.
I also replaced my rear tranny seal that was leaking. The seal I managed to remove, but I couldn't get out the sleeve that lives inside...we'll see if the seal holds.
After that my U-joint was squeaking at me, so I'll buy another tomorrow (mine doesn't have a grease port).
1987 R10
1976 K10
Old 07-28-2012, 07:44 PM   #25
74 stepside
74 stepside's Avatar
I worked on an F150 for a friend that had this problem. I broke loose all the sludge that looked like coal with a pick and used my shop vac to suck out all the junk. Then flushed out the engine. Did a oil change and adjusted the valves. That truck had 310,000 miles on it with a inline 6. Still running now.
74 stepside is offline   Reply With Quote
