Old 05-20-2003, 11:52 PM   #1
Benrs86
Benrs86's Avatar
oil leak suggestions
ive had this oil leak for a while and finally drove me insane. its a smallblock 350. the leak is on the lower half (not valve covers or back of intake). today after school i pulled the engine out, and took the oil pan off. the rear rubber gasket was sealed good, but part of the cork one looked like it could have been leaking. do i just put new gaskets there or should i put a new rear main seal while its out? it was 3 years ago now that i rebuilt that motor and cant remember how that seal works. i would have to take all the caps off and lift the crank out a little or how would i do that? thanks, Ben
Brandon, SD
69 GMC 1/2 ton 2wd
wide long bed with wood
3 on the tree
350 engine 4 bolt main
rv cam
AIM = Alphray04
Benrs86 is offline   Reply With Quote
Old 05-21-2003, 12:29 AM   #2
Bowed
If the rear seal was replaced 3 years ago it should be alright but then again it might be a good idea to replace it just to be on the safe side seeing the engine is out any way . If you remove the rear bearing cap the lower half of the seal comes out with it and and then just work the other half of the seal out with some thing small and blunt so you do not damage any surfaces. Then work in the new top half ( carefuly ) and assemble the rest and you do not have to touch the crankshaft . On the oil pan gasket it might be best to use a one piece rubber gasket , a little more expense but better . Good luck .
Bowed is offline   Reply With Quote
Old 05-21-2003, 12:44 AM   #3
cdowns
cdowns's Avatar
most good auto parts stores have an inexpensive tool kit for removing and replacing the main seals like he said just taking off the main cap slide the old one out and the new one in
Old 05-21-2003, 02:57 AM   #4
jimfulco
If you use cork gaskets next time, retighten them after a few months. Cork gaskets tend to loosen a little due to shrinkage. Usually they need a quarter-turn or so. Just don't over-tighten them to where the cork pinches apart. Same goes for valve covers.
jimfulco is offline   Reply With Quote
Old 05-21-2003, 08:22 AM   #5
TROYLV
rear seal
another trick i use on the two peice rear seal is to leave the ends about a 1/4 to1/8 inch offset from where the bearing cap mates up to the block. this stagers the seal in relation to that line and helps prevent a leak. if you need a pic let me know. troylv@lvcm.com
troy wilson
TROYLV is offline   Reply With Quote
Old 05-21-2003, 11:20 AM   #6
Benrs86
Benrs86's Avatar
thanks a lot, i might go return the cork one i bought for a one peice rubber and then get a seal. TROY i think i get what you mean, like twist both halves of the seal a little so the cab lines and the seal lines are offset. if i get a rubber seal i still use rtv silicone right? thanks a lot, Ben
Brandon, SD
69 GMC 1/2 ton 2wd
3 on the tree
rv cam
AIM = Alphray04
Old 05-21-2003, 04:36 PM   #7
theo70
COMING SOON...
theo70's Avatar
I would recommend Fel-Pro's one piece gasket. Hasn't failed me yet.
theo70 is offline   Reply With Quote
Old 05-21-2003, 04:39 PM   #8
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
after hesitating to try the one piece gaskets i now swear by them they make life so much esier
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 05-21-2003, 07:09 PM   #9
68 Stepside
huh?
68 Stepside's Avatar
I'm with the rest of the guys on the one piece rubber gaskets. I swear by them now too. Felpro's is nice too, comes with new, longer bolts and everything.
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
