Old 07-27-2012, 09:20 PM   #1
krazy_texan
krazy_texan's Avatar
Gauge cluster differences
Ok so I have 2 different trucks my dd is an 86 custom deluxe 10 4x4 with a 4spd the other is a 79 k20 silverado auto trans but it has a factory tach dash the 86 is what I'm going to fix up nice the k20 is going to be my hauler and snow plow how hard wiring wise would it be to put the 79 tach dash in my 86
Krazy Texan
My Trucks are made with Wrenches not Chop Sticks
1967 GMC 3/4 ton "Johnny Cash"
1990 v1500 suburban
1967 Ford f100 Swb 4x4 "green bean"
GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO
krazy_texan is offline   Reply With Quote
Old 07-28-2012, 12:58 AM   #2
mfwcar11
mfwcar11's Avatar
Re: Gauge cluster differences
not sure on trucks. but on my race cars just a green wire to the distributor,one to Ing, light, grown!!
68 chevy swd fleetside LT1/700R/under construction
72 chevy swb fleetside sb400/400 trans
73 chevy swb fleetside bb454/400 trans 2inch drop spindles 4bar c notch and airbaged/Under construction
07 GMC HD Durmax
Marshall Weaver
mfwcar11 is offline   Reply With Quote
Old 07-28-2012, 05:26 PM   #3
JMurray
I'm kind of in the same boat right now, I have an 82 C10 I put a 87 wiring harness in the dash but still have the 82 gauge cluster, I can't get my gauges to work, I'm assuming the locationg of the contacts on the printed circuit is different I have considered tying to hard wire all the gauges and eliminate the printed circuit.
82 GMC SW 2WD, 454 TH400, shaved mirrors, drip rails, tailgate, emblems. Midnight Blue, black and grey interior. Father son project in progresss.
JMurray is offline   Reply With Quote
Old 07-28-2012, 08:24 PM   #4
ray_mcavoy
I believe 78 to 87 all have the same pin-out on the cluster plug (except for trucks with the idiot light clusters). But it would be a good idea to double check with 79 & 86 wiring diagrams just to be sure.
It was the earlier years that had some differences in the cluster wiring with ammeters (73-75) instead of voltmeters (76-up) & mechanical oil gauges (73-77) instead of electric oil gauges (78-up).
As for the factory tach wiring, they use a separate 3-wire harness that plugs directly onto the back of the tach. The other ends of the wires go to power (fusebox), ground, and to the "TACH" terminal on the HEI distributor. Just transfer that harness over from the donor truck.
The printed circuit on the back of the cluster will automatically take care of the fuel gauge being re-located to the lower/left corner on the tach cluster. And the auto trans shift indicator just attaches to the cluster with a couple of screws so that's easy to swap.
ray_mcavoy is offline   Reply With Quote
Old 07-28-2012, 09:00 PM   #5
rcbildr
rcbildr's Avatar
A while back I upgraded the dash in my friend's 83 1-ton (SRW) from lights to gages using the instrument cluster from a 76 or 77 Suburban. Here's the link to my post about that, http://67-72chevytrucks.com/vboard/s...d.php?t=525870, there is some very helpful info that was posted there.
My Projects:
1960 GMC 1/2ton with 305 V6 (daily driver)
1963 Chevy 1/2ton 2wd...converting to 4x4
1967 Suburban 1/2ton 2wd
My Girlfriends Projects
1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver)
1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam
1978 Camaro Z28
rcbildr is offline   Reply With Quote
Old 07-31-2012, 11:04 AM   #6
motornut
78K & 79C Jimmys
motornut's Avatar
i did it to my 78
the gas gauge wire in the plug has to move
and add a ground for gas
i put the tach power to the pink/black custer power
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 07-31-2012, 12:36 PM   #7
Ski-me
Ski-me's Avatar
I converted my 89' cluster to a 91' electronic cluster and had to re-pin the connector. Maybe you can see if the 87' and 89' are similar
Hope this helps a little.....
Ski-me is offline   Reply With Quote
Old 07-31-2012, 02:22 PM   #8
motornut
78K & 79C Jimmys
motornut's Avatar
and one for the 78s may help
John
