07-30-2012, 10:34 AM | #1 |
Another drum to disc conversion question for the front page
I need to do a from drum to disc conversion on a 67 but to a 6 lug. I'm thinking I only need the spindle and outer rods from a local seller according to this guide:
http://67-72chevytrucks.com/vboard/s...68&postcount=4 Then picking up 6lug rotors, new calipers/pads, and possibly new ball joints as listed in that guide. I already have a new set but technically for a 67/68. Am I missing anything? |
07-30-2012, 04:35 PM | #2 | |
Re: Another drum to disc conversion question for the front page
07-31-2012, 09:01 AM | #3 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=531288 |
07-31-2012, 10:03 AM | #4 | |
67-72 parts collector,…
Like I posted in that thread,... 2) 67-70 truck owners can now purchase "year specific" standard and drop spindles, from many aftermarket suspension vendors. * No need to change ball joints. * No need to change tie rod ends. * These new "conversion disc brake spindles" are a true "bolt-on" mod to add disc brakes to your truck. Like these: http://www.performanceonline.com/196...dle-Set-16683/ $228.99 every day.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 07-31-2012 at 10:08 AM. |
07-31-2012, 10:37 AM | #5 | |
If I can help someone on the boards move parts and save money I would rather do that. IF I can. Naturally I don't want parts I can't use. |
07-31-2012, 10:07 AM | #6 |
They also have the 6-lug rotors you need,...
http://www.performanceonline.com/che...ersion-rotors/
07-31-2012, 10:42 AM | #7 | |
There is a off chance I have 5 to 6 lug "adapters" on my truck. I bought it a few months back and am yet to pull off the wheels and look, but I recall the last owner saying something about having them converted with adapters at 100 foot pounds of torque etc etc. I may reuse the adapters as I can get new 5 lug rotors for $33 each. Like I said before though, IF it can be done this way. |
07-31-2012, 12:10 PM | #8 |
Using 72 spindles is going to require you to spend alot more money than using the 63-70 conversion spindles.
1) Ball joint change 2) Tie rod change. 3) Special tie rod adapter sleeve to convert 5/8" tie rods to 11/16" diameter tie rods. $50-$60 a pair. Good luck. Let us know how it turns out.
07-31-2012, 12:36 PM | #9 |
Don't forget your 6-lug stock wheels won't clear the calipers. 71-87 stock, 6-lug wheels off a 4x4 will.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
07-31-2012, 02:36 PM | #10 |
07-31-2012, 01:21 PM | #11 |
Just a car guy
I figured my 1969 suspeension was all worn, so I upgraded to 73-87 spindles, a arms and tie rods.
What are the odds the a arm bushings, balljoints, tierods, etc.. on your 40+ year old truck are good? I upgraded to the 73-87 stuff added new parts. I used the A arms, centerlink and spidles from the 73-87. Bigger a arms, bigger bushings, bigger ball joints. All good upgrades for a driver. I used the CPP 6 lug rotors. My stock 1969 steelies cleared the roter set up as well.
1955 belair Blown Pro Street cruiser 1971 Camaro Pro Touring 1973 Vega Drag Car 1970 C20 tow rig |
07-31-2012, 01:39 PM | #12 | |
This is a great idea if you are replacing everything. Especially if you can refurbish everything first and then just swap the part on a weekend. I believe the pre-'71 steelies will work on the rotors,... its the calipers that cause the interference. Got any pics of your steelies?
07-31-2012, 03:25 PM | #13 | |
Just a car guy
07-31-2012, 02:11 PM | #14 |
My factory 69 6 lug wheels would not clear the caliper and would hit in certain spots. I had to run pre-71 wheels to clear the caliper.
07-31-2012, 02:42 PM | #15 |
07-31-2012, 03:28 PM | #16 |
07-31-2012, 02:57 PM | #17 |
buy the cpp parts from summit racing it is cheaper and FREE shipping...stay away from CPP
you need the 63-70 spindles, 71-87 -- rotors, calipers, bearing seal kit. 1- 2psi check valve and the custom fittings for your master and port valve to put the valve inbetween. And remove the stock 10psi check valve from the master. The oem wheels just touch the rim and you can grind a piece off the caliper(the brake pad really) for them to work or just get new rims.
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
07-31-2012, 04:09 PM | #18 | |
Run a disc/drum or disc/disc prop valve (or an after market adjustable prop valve),... and the correct disc brake master cylinder,... and you are good to go.
07-31-2012, 03:04 PM | #19 |
07-31-2012, 03:29 PM | #20 |
This is frustrating. Now I have to consider the wheels I am restoring may not even fit the disc brake setup I want to install.
07-31-2012, 03:31 PM | #21 |
^ The upgrade to disc has many twists and turns...
07-31-2012, 03:35 PM | #22 |
I would buy a full kit, but spending $1300 on something that appears to run sub $300 just breaks my balls and my brain.
A puzzle is exactly what I didn't want. As an engineer I feel compelled to figure this out. |
07-31-2012, 03:46 PM | #23 |
$219 spindle MAKE SURE YOU get the 63-70 one if you have stock ball joints(aka just took off the drum brakes)
$350 kit rotor cal/pads, bearings, seals, caps,nuts, 1-2psi check valve $10 fittings for master Got all the cpp stuff from Summit racing bag it while your in there for sure 2- bags and 2 Schrader valves top plates and bottom cups, does the trick ***************** |
07-31-2012, 04:06 PM | #24 | |
I can pick up Oreillys 1973 rotors and loaded calipers for $120. I'm sure bearings and seals would only be a few bucks more. |
07-31-2012, 03:58 PM | #25 |
You can find the 6 lug 71-87 wheels relatively cheap. I bought 5 for about $200 shipped to me and turned around and sold two the day I got the 5 in.
I have one left if your interested. It would need to be sandblasted and painted. |
