Old 07-30-2012, 02:56 PM   #1
5bassman
Tailgate trim, best way to shine it up?
I have an 86 Silverado, I need the trim to match the paint, shiny. How do I shine up the trim on the tailgate and the bed corner pieces?
5bassman is offline   Reply With Quote
Old 07-30-2012, 03:00 PM   #2
Firebirdjones
Re: Tailgate trim, best way to shine it up?
If you are speaking of the big trim piece on the tailgate, I believe that is supposed to be a brushed look and somewhat dull (not shiny)
But if you want to shine trim, I use this stuff on all my stainless and other small pieces on the classic cars...best stuff out there in my opinion. Has many other uses too.
https://www.wenol-polish.com/
If you are speaking of the lower trim moldings, then you have an issue. During these years of production that is a rubber flexible molding that has that simulated chrome attached (more like plastic) and then it usually has a clear covering over that for protection. Usually over time that clear coating starts peeling off. No way to shine this stuff up really. If it's discolored or peeling it's probably time to replace it.
Firebirdjones is offline   Reply With Quote
Old 07-30-2012, 03:02 PM   #3
5bassman
At an angle it almost has a chalky look to it.
Old 07-30-2012, 03:43 PM   #4
JWall
Frequent Flyer
JWall's Avatar
We polished out the trim on my Dad's 76 including the tailgate band, cab trim below the window, etc.
We polished it out with some jewlers rouge and a buffing wheel then some good metal polishing... it took a little time but looks pretty cool.
- Justin
1 Owner 1976 SWB
Old 07-30-2012, 03:45 PM   #5
5bassman
Looks great! I like that. I might have to try that. My corner pieces don't come close to matching the stick-on chrome on the side and back.
Old 07-30-2012, 05:18 PM   #6
truckfan
truckfan's Avatar
i will watch this
1981 Chevy C30 440 Holmes 42K one owner miles
truckfan is offline   Reply With Quote
Old 07-30-2012, 05:21 PM   #7
INSIDIOUS '86
INSIDIOUS '86's Avatar
Jwall isnt there a coating on the tailgate trim?
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 07-30-2012, 05:32 PM   #8
Firebirdjones
Some of this stuff will have a clear coating on them (usually the aluminum pieces), which will all have to be stripped to buff the aluminum or stainless underneath.
On these aluminum pieces, once it's stripped and polished, it becomes a continual process to keep it looking nice, the aluminum dulls quickly in the weather without a protective coating and also becomes subjected to corrosion.
I wasn't aware you wanted to get that serious with the polishing Bassman. In order to do that you'll have to do what JWall did and break out the rouge and buffing wheels, take the pieces off the truck, and plan to spend days on it
Old 07-30-2012, 06:00 PM   #9
INSIDIOUS '86
I want to do the same thing since the clear coat on my thin tailgate trim is kinda milky. But the damned coating wont come off
Old 07-30-2012, 08:49 PM   #10
JWall
Frequent Flyer
JWall's Avatar
We did that trim several years back so I cant remeber about the coating... if there was we cleared that off first.
My dad uses that truck for shows & cruise nights so its hard to say about the durablity of it if it was daily driven.
The truck was painted 8 or so years ago & thats when we did it & I think we've only repolished the tailgate & cab bands once.
- Justin
1 Owner 1976 SWB
Old 07-30-2012, 10:37 PM   #11
6772fan
Active Member
6772fan's Avatar
5bassman, Really sharp truck and doesn't look like it needs a great deal more shining as is. I've ordered a tube of the red polish that Firebirdjones refers to (have the same problem with my 87) Thanks for the post!
Lane
1979 Chevy SWB- (Second owner- Father in Law was first)
1979 Chevy Silverado SWB-Red/Red
6772fan is offline   Reply With Quote
Old 07-30-2012, 10:49 PM   #12
5bassman
Thanks! The bed corners are duller than the tailgate piece but they both could use polishing. I have a roll of the side molding that I will be replacing soon.
Previous owner did a poor job of putting it on.
Old 07-31-2012, 02:19 PM   #13
Firebirdjones
That stuff is the best out there for maintaining stainless, aluminum, brass, etc...You'll like it.
I've even used it to polish plastic taillight lenses, plastic headlights, you name it and it works on it.
I like it because you can take a somewhat dull piece of stainless (say window trim) and use it by hand with a rag and some rubbing, it comes out like chrome with a little time spent.
Now if you want to buff something that has alot of scratches then rouge and a buffing wheel is the way to go.
Old 07-31-2012, 12:09 PM   #14
trout
im watching also
Edited by staff
trout is offline   Reply With Quote
Old 07-31-2012, 12:49 PM   #15
egaray281
egaray281's Avatar
i added a tailgate trim that i got from a junkyard to my truck i used something called steel wool from autozone and it worked great it gave it a nice shine but of course its not super shiny since its made to look some what dull i guess from the factory but it cleaned up nice!
egaray281 is offline   Reply With Quote
Old 07-31-2012, 12:58 PM   #16
88Jimmy4x4
88Jimmy4x4's Avatar
its designed not to be too shiny so when the vehicle behind you headlights hit it they dont shine back in his face.
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 07-31-2012, 02:16 PM   #17
Firebirdjones
Yep, same reason stainless backed rear view mirrors were also phased out starting around 1970, so oncoming traffic didn't get blinded by the reflection.
Old 07-31-2012, 02:22 PM   #18
egaray281
egaray281's Avatar
thats makes sense?
Old 08-01-2012, 03:18 PM   #19
DIRTY HAIR
Originally Posted by 5bassman View Post
i have an 86 silverado, i need the trim to match the paint, shiny. How do i shine up the trim on the tailgate and the bed corner pieces?
posted via mobile device
nice truck!
DIRTY HAIR is offline   Reply With Quote
Old 08-01-2012, 04:44 PM   #20
5bassman
Originally Posted by DIRTY HAIR View Post
nice truck!
Thanks! Was going to buy it for my son (pictured) but got it for myself instead. 117,000 miles but engine rebuilt at 79000 with larger cam and pistons, hits a good lick but not too much. Supposedly a $5000 paint job,nice original interior. Nice dual exhaust, a little louder than I like. Might replace with some quieter Magnaflow mufflers.
