Old 07-30-2012, 09:44 PM   #1
68 Stepside
huh?
68 Stepside's Avatar
Any early Impala guys here? 62 grille question.
Hey all,
I've outlined the new project I've been working on in the following thread: http://67-72chevytrucks.com/vboard/s...d.php?t=536286
My father-in-law and I changed out the grille the other day (the original was bent up due to a minor fender-bender at some point) and the very well used replacement he bought doesn't fit well. The holes for the "teeth" in the top of the original grille are much larger than the holes on the grille we put in. Also, the "teeth" he ordered to replace the original grille teeth he couldn't remove don't come close to matching. In addition, the center of the grille sticks out quite a bit more than the original. We replaced the tweaked brackets with a set of straight originals.
Were there any differences in 62 grilles or the teeth on the top of them?
In the pics I posted, you can see the center of the grille seems to be sticking out pretty far. In the pic of all the teeth mounted on the grille, note the size and rounded-ness of them. In the pic of the single tooth, note it's much taller and squared off.
Any info you could provide would be greatly appreciated.
Thanks,
TJ
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 08-03-2012, 12:47 AM   #2
impalamark
impalamark's Avatar
Re: Any early Impala guys here? 62 grille question.
TJ
I have owned two dozen 62 impala's in the last 30 years and have seen diffeences in trim on them depending on the assembly plant and I understand chevrolet had multiple
sources for many of the parts . why the marked differences i don't know except to
say 50 years ago you could not send a CAD file over the internet from factory to factory. i have seen these variations on original parts but not the fitment issue in the picture but several parts account for that fitment :grill-grill support-hood -hinges -core bracket etc.
Now that these parts are being reproduced and sourced from around the world it gets even harder. my only suggestion is to try to source the best original parts you can
Good Luck
the avatar was my 62 I owned for 27 years
84 chevy short short bed black
84 gmc long bed copper/ buckskin
88 chevy k5 blazer white
Life's short make the most of it
Mark aka impalmark
impalamark is offline   Reply With Quote
Old 08-18-2012, 03:35 PM   #3
Torrey72
Rollin in my K5 toaster
Torrey72's Avatar
Looks like your car has an under bite. The top of the grille needs to line up with the leading edge of the hood, but you know that. Here are some pics of my 62. The odd tooth you have pictured belongs in the center of all the teeth. hope this helps.
-Torrey
Torrey72 is offline   Reply With Quote
Old 08-18-2012, 03:41 PM   #4
Torrey72
Torrey72's Avatar
some more.
Old 08-18-2012, 03:47 PM   #5
Torrey72
Torrey72's Avatar
Two more. If you need more, let me know
-Torrey
Old 08-18-2012, 05:49 PM   #6
68 Stepside
huh?
Wow,
Thanks for the responses guys. Torrey, I'll have to check the measurements on my grill now and see what I can do. Thanks for all the pics, how about some pics and specs of your entire car??
RIP El Jay
