Old 08-02-2012, 12:23 PM   #1
KrazyRay
KrazyRay's Avatar
3.07 posi gear set
SOLD!!! I have a posi gear set from a 70 1/2 ton truck. Everything looks great except the ring gear has rust on one side from water condensation from sitting in one place for years. I recommend changing out the ring rear. $150 plus shipping. DesertCat is first up.
Thanks,
Ray
KrazyRay is offline   Reply With Quote
Old 08-02-2012, 12:29 PM   #2
HotRod C/10
HotRod C/10's Avatar
Re: 3.07 posi gear set
Next inline plz.
SOLD -77 CHEYENNE SWB,
LS SWAPPED
-1976 SILVERADO
YUBA GOLD/NEUTRAL (2-TONE)
HotRod C/10 is offline   Reply With Quote
Old 08-02-2012, 12:31 PM   #3
w314speed
I'll get in line after DesertCat. This is the ring and pinion and posi case removed from the housing and shipped? Shipping to 30127? I would want all the sims and spacers with the carriers bearing sides marked for easy install. Thanks, Dan
I GUESS I DIDN'T TYPE FAST ENOUGH!!!!
w314speed is offline   Reply With Quote
Old 08-02-2012, 12:52 PM   #4
DesertCat
DesertCat's Avatar
Yessir, I'll take it. PM me the total to 85295 please.
My build thread - Devastation and Reform http://67-72chevytrucks.com/vboard/s...d.php?t=567131
DesertCat is offline   Reply With Quote
Old 08-02-2012, 03:19 PM   #5
KrazyRay
KrazyRay's Avatar
Here's all that's included. pm sent to DesertCat.
Thanks,
Ray
Old 08-02-2012, 04:05 PM   #6
DesertCat
DesertCat's Avatar
Payment sent.
Now I'll be able to
Old 08-02-2012, 06:01 PM   #7
HotRod C/10
Just out of curiosity....... Can a person put 3. 73's on this unit?
LS SWAPPED
-1976 SILVERADO
Old 08-02-2012, 06:36 PM   #8
DesertCat
DesertCat's Avatar
From what I understand, this is a 3 series unit and Richmond makes gears up to the 4.56 that will fit this. But for stock gearsets you would want a 4 series unit for 3.73 and numerically higher. I am no expert on this... that is just the info I have read about it. YMMV...
Old 08-03-2012, 09:30 AM   #9
Hertzdaddy
That is my understanding as well. Aftermarket gearsets from 3.73 up that fit on the 3-series are made special and won't fit onto factory 4-series carriers. I believe the ring gears are thicker. You can also get spacers to enable using oem style 4-series rings on 3-series carriers.
Hertzdaddy is offline   Reply With Quote
Old 08-03-2012, 12:46 PM   #10
HotRod C/10
How do you identify the 3 and 4 series?...... 3.73 is a4 series oem
LS SWAPPED
-1976 SILVERADO
