Help identify what this is / was used for...
So I've finally begun my 50' 3/4ton project, and as I was looking over the truck the other day I noticed something that I had previously overlooked.
I'm not sure if it was something that a previous owner added, or if this was from the factory. Either way I can't figure out what it would have been used for. It might be something obvious, but for the life of me I can't figure it out. |
Re: Help identify what this is / was used for...
That was most likely a mount for a mirror. Doesn't look factory to me but that is about where the factory mirror was mounted.
Aftermarket mirror. And they often bend or break the metal around the base.
On the optional{GM} mirror the screws are farther apart. look under the dash at the inside of the cowl you will see a sheet metal backer with 2 holes in it that is where tha mirrors mount. The passanger side morror was an option. Last edited by mknittle; 08-04-2012 at 10:43 AM. |
Yep, a big mirror. You can look at those brackets on five trucks and no two of the will be mounted exactly the same on the right hand side. I think they flipped a left hand bracket and bolted it on.
Usually they were on the 1 tons and up and both of my 1-1/2 ton cabs have that bracket. |
I agree. The ones I have seen have usually been on the bigger trucks, most of them still had the mirrors and arms on them.
1970 Nova 327/T5 (my 1st car) 1971 K-20 350/350/205 (winter DD) 1953 GMC Suburban 1968 Chevy Bel Air 1976 Chev C-10 1972 Skylark (suncoupe) 1 of 3943 made |
