Old 08-04-2012, 08:27 AM   #1
66clow
66clow's Avatar
Diy roof rack 2 fleetside?????
With the success of DWC'S sweet roof rack on his burb it got my wheels turning. Roof rack on a fleetside???? I was familiar with i.o.racks on VW singlecabs so why not a fleetside??? I quickly found a sweet deal on Craigslist for the same brackets as DWC'S for 25 bucks. Here is the mock up stay tuned off to Lowe's to pick up some wood. Open to ideas before it is too late.
66clow is offline   Reply With Quote
Old 08-04-2012, 11:26 AM   #2
oem4me
Re: Diy roof rack 2 fleetside?????
Cool. Since the truck rack is going to be much shorter than the burb rack, the same length load would have less support and create greater stress on the cross rails (in my mind, I picture a surfboard). I would beef up those rails a bit to be safe, and use some good strong wood like oak or ash. Have fun.
Old 08-04-2012, 11:59 AM   #3
DoubleL
DoubleL's Avatar
Can't wait to see the finished project.
DoubleL is offline   Reply With Quote
Old 08-04-2012, 12:23 PM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
cool idea. My 66 step had a roof/ladder rack on it at some point. I never saw it, but the holes in the bedside and dimples on the roof tell the story lol.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 08-04-2012, 01:49 PM   #5
MusicMan70
MusicMan70's Avatar
Nice and Good score on the brackets too!
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 08-04-2012, 03:49 PM   #6
66clow
66clow's Avatar
OK I'm stuck and not sure where to go. I have 1x3's going across which seems OK. Not sure for the top. The 1x 2's seem kinda wimpy showing on the Dr's side not sure if I should do the 1 x 3's showing on the passenger side. Thinking possibly 2 x 2's to give it some meat see picture of 2 1 x 's together. What you think?
/IMG]
Old 08-04-2012, 04:22 PM   #7
66clow
66clow's Avatar
Old 08-04-2012, 05:55 PM   #8
oem4me
The 1x's front to back are fine. where you need girth is in the two cross rails that have the brackets attached. Those two pieces hold the whole load.
Old 08-04-2012, 07:48 PM   #9
66clow
66clow's Avatar
I think what I will try is to put rails along the sides of the cross rails. Do you prefer the wider 1 x 3's or the skinner 1 x 2's? I don't plan to put much weight up there but I do see what you are talking about supporting anything.
Old 08-05-2012, 02:12 AM   #10
oem4me
1x2 rails alongside the 1x3 would really help the strength, hopefully without making it look too bulky. Perhaps even a single 1x2 glued and screwed underneath making a "T" in between brackets would do?
Play around a little to see what looks right.
BTW I really like your truck. The color, wheel and cap choice, stance, everything. Have fun.
Old 08-05-2012, 12:22 PM   #11
66clow
66clow's Avatar
Thanks for the compliment, I appreciate the feed back. I really like the metal tubing with the wood and may check to with some of my body shop connections to see about welding in some tubing. I like the T idea and will probably incorporate that and use oak wood in the end after the mock up. I will post an update as I go along. I also found this rack which is pretty sweet below.
I'll figure something out.
http://classicracks.com/racks.htm[IMG]
http://classicracks.com/racks.htm[/IMG]
Old 08-04-2012, 06:11 PM   #12
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
It might make noise as the wind goes through and across the wood. Try to radius the face of the boards to break the wind noise. I like the way it looks. If you use hardwood you might be able to have a xylophone up there. Looks great.
Old 08-04-2012, 06:30 PM   #13
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I like the combo of wood and tube like on the old Westy' roof racks.
Old 08-04-2012, 06:43 PM   #14
66clow
66clow's Avatar
That definitely be my choice if I could bend and weld tubing. I will incorporate some type of metal railing. Thanks
Old 08-11-2012, 08:58 PM   #15
66clow
66clow's Avatar
Update on DIY roof RACK. Worked on putting on the T for the cross supports. Much sturdier and looks better. There was too much space between the roof and the bars. Used glue and screws. Thinking of using copper piping for the side rails for something different, what you think? ????
Old 08-14-2012, 11:18 AM   #16
66clow
66clow's Avatar
[QUOTE=66clow;5534483]Update on DIY roof RACK. Worked on putting on the T for the cross supports. Much sturdier and looks better. There was too much space between the roof and the bars. Used glue and screws. Thinking of using copper piping for the side rails for something different, what you think? ????
hh513/66clow/C10/2012-08-11_19-18-08_729.jpg[/IMG]
Old 08-12-2012, 12:05 AM   #17
ChevyFreak60
ChevyFreak60's Avatar
The racks looking good bro!! I love the way that truck sits.
1960 Chevy Stepside 2wd
1966 Chevy Fleetside 2wd
1965 Chevy Suburban 2wd
1965 Chevy Fleetside 4X4
1960 Chevy Fleetside BBW 2wd
ChevyFreak60 is offline   Reply With Quote
Old 08-12-2012, 08:46 AM   #18
aerotruk63
aerotruk63's Avatar
These them?
http://www.nrsweb.com/shop/product_list.asp?deptid=1379
Old 08-12-2012, 09:14 AM   #19
66clow
66clow's Avatar
Exactly and it's nice to know replacement parts are still available.
Old 08-12-2012, 10:12 AM   #20
oem4me
Yep, I think you are on the right track. Now it's onto the details like the number and spacing of slats, maybe throw in some light radiuses on corners and ends, and the copper pipe idea has potential too.
Seldom a design/build project goes from start to finish without several changes along the way, but that's the fun part, right? Keep us posted.
Old 08-18-2012, 07:22 PM   #21
66clow
66clow's Avatar
Slats mounted, came out pretty good. Errors made but OK. Need to add rails and stain. Will do a final redo in oak. Has been fun playing around with it.
Old 08-18-2012, 08:11 PM   #22
aerotruk63
aerotruk63's Avatar
Could use two more slats at each extremity, radius them at the front and back to follow the roof line.
Old 08-18-2012, 09:39 PM   #23
66clow
66clow's Avatar
Good idea, I'll try that. I know it needs some type of different lines somewhere. I just couldn't picture it. After fooling with all the straight line slats that's all you see after a while. Still open to other ideas . Glad I'm using the really cheap wood so the final deal should be error free with the oak wood. So far I probably have about $60 in it including the cost of the C.L. brackets. Not bad for a trial run.
Old 08-19-2012, 03:23 PM   #24
66clow
66clow's Avatar
Made some cuts, hope this was what you where referring to. Plan for rails and probably a oak stain??. Will for back and use real oak wood for final rack.
Old 08-18-2012, 10:17 PM   #25
Pop's C-10
Pop's C-10's Avatar
I like tha look it & tha whole truck in general..you going to leave it raw or stain it?..
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
