Old 08-05-2012, 04:37 PM   #1
yossarian19
Hydraulic clutch pedal assembly?
What have you guys used or seen that works well for putting a hydraulic clutch assembly into a TF?
The goal is to put hydroboost brakes & hydraulic clutch mounted on the firewall. I say the firewall, but really, I mean "wherever it is going to fit easiest and or cheapest"
Figured I'd ask a question as opposed to reinvent the wheel...
Thanks!
yossarian19 is offline   Reply With Quote
Old 08-05-2012, 04:53 PM   #2
va4cqd
Re: Hydraulic clutch pedal assembly?
what year truck?
va4cqd is offline   Reply With Quote
Old 08-05-2012, 05:01 PM   #3
yossarian19
It's a '57.
I'm pretty sure at this point it will get a 4.8 LR4 + NV3500 manual trans. The 4.8 is already in the shed, so that part is all but certain.
I'd like to minimize fabrication, since I am not yet a skilled fabricator. If need be, though, I can get help, struggle through or farm out.
Old 08-07-2012, 09:38 PM   #4
low67chevy
Im putting hydro onto my 56 and ive just picked up a set of hyd clutch pedals from a 88 k30 pickup they will fit under the dash with very minor mods just my 2 cents.
low67chevy is offline   Reply With Quote
Old 08-08-2012, 01:39 PM   #5
_Ogre
_Ogre's Avatar
i have a hydroboost mounted under floor using the stock pedal
still lots of room to use the stock clutch pedal
firewall or under floor: either one will require fabrication.
you want cheap, use the stock pedals in stock location
also keeps the firewall clean
shop air compressor timer
brake pedal, clutch pedal
