08-06-2012, 09:34 PM | #1 |
what is best way to clean and paint frame?
I have my truck mostly taken apart and I want to clean and coat the frame with something. I'm on a budget since all my money went to porterbuilt and don't have the money to powder coat my frame so what is my next best option for doing it myself? I don't have any body work experience, I just want my frame to look newer and have a protective coating on it.
Posted via Mobile Device |
08-06-2012, 09:39 PM | #2 |
Re: what is best way to clean and paint frame?
Por-15
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD Using your turn signal is not "giving information to the enemy" 67-72 FAQ |
08-07-2012, 09:48 AM | #3 | ||
"I ain't nobody, dork."
POR-15's cleaning solvents work very well. The Marine Clean and Metal Ready are what I've been using for quite some time. They work extremely well.
Gary
08-07-2012, 10:14 AM | #4 |
I used POR15 prep products and then the gloss black. Very durable product and really not all that expensive in my opinion. It will "chalk" if exposed to sunlight however. My frame looks fantastic and is well protected.
08-06-2012, 11:19 PM | #5 |
I find POR expensive and it's not as good as its said to be..
I would go buy a cheap sandblaster and sand.. Sandblast the frame. Paint it with GM reconditioning paint. It goes over bare metal just like GM did when these trucks were built new. Posted via Mobile Device |
08-07-2012, 08:53 AM | #6 |
I've been looking at Master Series Coatings: http://www.masterseriescoatings.com/index/. I've seen a number of threads on this site where members recommend using this for frames/floors, etc. It's supposed to be better than POR 15 and less expensive. Can't speak from experience...yet. Hopefully in 3-6 months I can give my opinion. - Matt
Matt Criswell - Lyman, SC 1972 Chevy Cheyenne SWB - Build: Porterbuilt State 1 Front & Rear, Bolt in Notch, McGaughys 2.5 Drop Spindles, Boyd Welding Fuel Tank UPSTATE SC GM TRUCK CLUB: FACEBOOK WEBSITE |
08-07-2012, 10:27 AM | #7 |
Moderator
POR and all of their prep products.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
08-07-2012, 12:46 PM | #8 |
Go to the dollar store buy some cheap oven cleaner (PowerHouse - yellow can). Spray on let sit pressure wash off. Scrape with a putty knife, wire wheel on a drill. Rinse and repeat. I used Eastwoods chassis black paint and primer. Went on easy holds up nicely and is not that expensive. Just need to apply a few coats. If you brush the primer on be carefull it drys pretty quick and you could see brush strokes.
08-07-2012, 01:06 PM | #9 | ||
When you use the POR-15 Marine Clean... you don't have to scrape anything off but the thickest gunk areas (like the crossmnember under the engine). Best part about it is... you don't need a pressure washer, and only need to do it once.
Gary
08-07-2012, 01:07 PM | #10 |
Moderator
This stuff is incredible....it's like simple green x 1000.
08-07-2012, 01:37 PM | #11 |
Thanks for the thoughts everyone. Cleaning will be easy because my frame is super clean for its age with a few surface rust spots. Thanks for the info.
08-08-2012, 05:48 PM | #12 |
I have frames sand blasted (alot faster & better than wire wheel) and paint them with satin/antique black Chassis Saver. http://www.magnetpaints.com/underbody.asp
Eric Evans Queen City Shop Truck http://67-72chevytrucks.com/vboard/s...34#post6139834 66 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=543110 |
