Are stock 16"x5" rims different on '71 & up disc brake trucks?
Hello,
In my searching for stock 16"x5" 6-hole wheels for my '71 GMC K1500 Custom, I read this thing about the wheels changing so they'd have room for the 'new' front disc brakes on '71 +. Are they different? Should I be looking for '71 and up wheels? Thanks! |
#2 | ||
"I ain't nobody, dork."
Re: Are stock 16"x5" rims different on '71 & up disc brake trucks?
They will be 5 lug instead of 6 lug. So you have a '70 and earlier, non-disc 6 lug, on a '71?
Gary
K10/1500 6 lug 16s were all tube type, I thought. There is a large section in the parts manual on wheels that should be reviewed. As I remember it specified which wheels were approved tube and tubless applications. Here is a '71 K10 tire option clip for you showing the RPOs R61, R64, R65 and R69 you might want to watch for.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban Last edited by SS Tim; 08-08-2012 at 12:51 AM. Reason: picture went missing |
The wheel centers have a different contour to clear the calipers on disc brake trucks. Drum brake wheels had a "flatter" center, if that makes any sense.
A typical 71-87 6 hole GM wheel looks like this (although this one is 15") ![]() The older wheels were not as deep in the center section where the lug holes are and may have hubcap clips or the rivet holes for them.
1971 GMC C2500 Custom Camper - Second Owner. 350/TH350, Dana 60 Rear. |
Thanks you guys for your responses, I know way more now what to look for. Wilbilt, on the wheel photo, I see 4 nubs for the hub cap, but I swear I've seen wheels with only 3, do you know if there were both or is there is some significance there year or plant wise?
#6 | |
Many tube-type wheels have centers that are riveted in place (not airtight) and lack the circumferential ridge on each side near the bead seat that helps maintain bead pressure to hold air. It also seems like tubeless wheel are thicker (heavier), or maybe I am just getting older. ![]()
