Old 08-11-2012, 12:15 PM   #1
williamsboys
williamsboys's Avatar
Question brake line clips
Im working on installing all new brakelines from front to back. I got the dual line from a booster to disc and drum on back. I dont have the body on the frame yet but im looking for diff ways to secure my lines. I ordered clips from lmc but the just have a hole in them as if i need to bolt them on. But the only one i saved from teardown is the kind you push threw the frame. Just wanting some ideas and pics please and where you got the clips would be great. Thanks
williamsboys is offline   Reply With Quote
Old 08-11-2012, 06:27 PM   #2
williamsboys
Re: brake line clips
Nothing?
Old 08-11-2012, 09:28 PM   #3
rbar
rbar's Avatar
I used expensive stainless half round clips designed for brake lines that I drilled and tapped holes for in the frame (10-32). On the cross member I used rubber covered metal clips that would hold double lines. The local hot rod shop sold them for a couple of bucks apiece and then I noticed harbor freight has an assortment for cheap. Even though I was done, I bought them and compared and I can't see a difference. These could be used the length of the frame as well.
1963 Chevy stepside 327
1965 Chevy swb 383
1996 Mystic Mustang Cobra
2009 Pontiac G8 GXP 415hp/415tq 6speed
rbar is offline   Reply With Quote
Old 08-11-2012, 10:01 PM   #4
bhc41051
bhc41051's Avatar
Maybe try inline tube...
http://inlinetube.com/clips%20brake%...fuel/clips.htm
bhc41051 is offline   Reply With Quote
Old 08-11-2012, 10:26 PM   #5
williamsboys
Thanks guys. Any body got pics of the brake hose from front caliper to crossmember, i ran mine but it seems like there too long.i just pushed excess of hose to the front of truck.
Old 08-11-2012, 10:34 PM   #6
bama63
bama63's Avatar
i went to the local electrical supply and bought a 50pc box made by thomas and betts for $6.00 i believe the number was an-3 and is 3/16 id x 1/2 inch wide metal identical to the inline tube clamps that cost $1.00 each
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice
bama63 is offline   Reply With Quote
Old 08-11-2012, 10:35 PM   #7
williamsboys
Cool. Thanks man
