08-11-2012, 12:21 PM | #1 |
What to use for door jamb wiring?
Hy guys I am almost done with my build andm having trouble with door jamb wiring. I have to run wires for power windows and maybe speakers. There seems to be very little room between the door and the cab jamb. Wht are you guys using for loom. Pics would be great. I have already painted and don't want to screw this up.
08-11-2012, 12:37 PM | #2 |
Re: What to use for door jamb wiring?
not sure what year truck you have, but look at post #25 in my build for what i used on my 58.
i ran: power window, speaker, door solenoid and ground wires plus a door release safety cable thru my door looms.
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
08-11-2012, 01:03 PM | #3 |
Look at Kustombrads thread, he has a slick method using screen door springs.
08-11-2012, 02:41 PM | #4 |
ogre
v v slick set up ! |
08-11-2012, 04:05 PM | #5 |
Sorry I forgot to mention it is for a 52 pickup. Ogre, I read your thread this morning before I posted, you have a very slick setup. I was hoping for something a simpler. I will look at custombrads setup. Thanks for the replys guys.
08-12-2012, 01:32 AM | #6 |
I used these spring loaded one.. good for close openings.
08-13-2012, 12:29 PM | #7 |
Who makes those?
___________________________ 1959 Apache Short Fleetside, 1959 Apache NAPCO Long Stepside, 1957 3100 with 59 fleetside bed 1957 5700 LCF Crew Cab "Big Bertha",1959 GMC F370 1958 GMC 600, 1946 Chevy, 1959 Viking 60 LCF 1974 Elcamino SS, 1979 6500 GMC Tilt Bed Wrecker Big Bertha Build |
08-13-2012, 02:24 PM | #8 |
found them....never mind
08-13-2012, 08:44 PM | #9 |
08-13-2012, 12:04 PM | #10 |
Remember if you are doing power windows, the drivers side has more wires so needs a bigger loom to fit them in, my mistake, I started on the pass side first.
Retired and too busy to work. |
08-14-2012, 07:19 PM | #11 |
parkwood: do those work for speakers?
08-14-2012, 07:38 PM | #12 |
08-14-2012, 08:35 PM | #13 |
I've seen them used for speakers, the only downside, if it is one, is what parkwood mentioned about opening the doors and they go out til the door is closed.
08-15-2012, 01:30 AM | #14 |
56 - autocross
where do those connectors come from?
08-15-2012, 05:53 PM | #15 |
Probably China via Ebay.
http://compare.ebay.com/like/3904511...Types&var=sbar http://compare.ebay.com/like/3706387...Types&var=sbar http://www.speedwaymotors.com/search...g-harness.html
